Subsonic 4.6 released
Re: Subsonic 4.6 released
Postby sindre_mehus » Thu Dec 29, 2011 7:39 pm
I'll add an option to suppress content length estimation in the next Subsonic release, since this causes problems for some clients.
Postby wraithdu » Fri Dec 30, 2011 3:54 am
Thank you for the option! How would disabling content length affect network robustness, for example over cellular on the Android app? How did previous versions of Subsonic operate?
wraithdu
Postby sindre_mehus » Fri Dec 30, 2011 10:34 am
That shouldn't be affected at all. Content length is optional in http, and prior to 4.6 is was never set for transcoded media.
Postby wraithdu » Sat Dec 31, 2011 2:45 pm
Is that an easy modification to make? Could I make that change on my existing 4.6 install?
wraithdu
Postby bile » Tue Jan 03, 2012 9:41 pm
What was "Fixed a case where guessing the title and track number failed" ? I am still have the same issue with "01 Ghosts I" where it gets read as "Ghosts I"
bile
Postby wraithdu » Sun Jan 08, 2012 5:48 am
I have a suggestion or bugfix (depending how you look at it) for the next version. As it relates to the Android app (perhaps the web player as well?) if you have bandwidth set to unlimited, then it actually defaults to 128 for the %b parameter. Now, normally you wouldn't see this, as unlimited bandwidth wouldn't trigger a downsample for mp3s. However if you have transcoding settings that use bitrate, then any transcode will be passed a bitrate of 128... not desirable from my standpoint. I'm not sure what the proper fix for this is, but perhaps have 'Unlimited' send a bitrate value of the max available (320).
wraithdu
Postby kdid » Fri May 11, 2012 12:58 am
My friend just upgraded from 4.5 to 4.6 and before the upgrade he was able to share video up to around 3000 kbit/sek for .flv files.
This was for H264 version .flv files coded in around 1500 kbit/sek.
After the upgrade the transfer speed dropped to around 700 kbit/sek for same type file.
Anyone knows what the problem can be.
Regards
kdid
-- kdid
kdid
Previous
Return to Announcements
