Supersonic 1.1.6 - Foobar2000 inspired multi-platform Player
Re: Supersonic 1.1.6 - Foobar2000 inspired multi-platform Pl
Postby Rinaldus » Sun Feb 10, 2013 1:33 pm
Athou wrote:I forgot to fix the issue for all hyperlinks, it should now work with the 1.1.7 zip. Let me know !
Yes, it works now, thank you very much. But I received about 100 windows with errors while cynchronizing my library. Here's screenshot: http://s40.radikal.ru/i089/1302/13/6450373078a7.jpg
And all text in this window:
Message:
    java.util.concurrent.ExecutionException: java.lang.NullPointerException
Level:
    SEVERE
Stack Trace:
    java.util.concurrent.FutureTask$Sync.innerGet(FutureTask.java:222)
    java.util.concurrent.FutureTask.get(FutureTask.java:83)
    be.hehehe.supersonic.service.Library$1.doInBackground(Library.java:176)
    javax.swing.SwingWorker$1.call(SwingWorker.java:277)
    java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
    java.util.concurrent.FutureTask.run(FutureTask.java:138)
    javax.swing.SwingWorker.run(SwingWorker.java:316)
    java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
    java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
    java.lang.Thread.run(Thread.java:662)
null
    be.hehehe.supersonic.service.Library$1$1.call(Library.java:154)
    be.hehehe.supersonic.service.Library$1$1.call(Library.java:131)
Rinaldus
Postby Athou » Sun Feb 10, 2013 2:03 pm
Ok there was an error when some of the metadata was not present, it should be fixed with the 1.1.7 zip now, could you try now please ?
Thanks for the bug reports !
Athou
Postby Rinaldus » Sun Feb 10, 2013 5:48 pm
Yes, those many errors are dissappeared and I got only 1 error in synchronization now. Here's its text:
Message:
java.util.concurrent.ExecutionException: be.hehehe.supersonic.utils.SupersonicException
Level:
SEVERE
Stack Trace:
May I ask you to add one feature? Can you add another view that keeps Subsonic folder structures? Many users create folders with albums instead of fill right id3 tags and this view mode will be more comfortable for them.
Rinaldus
Postby Athou » Sun Feb 10, 2013 6:30 pm
Do you have the whole stacktrace please ?
I'll see what I can do about a tree view.
Athou
Postby Rinaldus » Sun Feb 10, 2013 7:54 pm
Athou wrote:Do you have the whole stacktrace please ?
What is it? You mean console output?
Rinaldus
Postby Athou » Sun Feb 10, 2013 9:30 pm
I mean your quote seems to be truncated
Athou
Postby Rinaldus » Mon Feb 11, 2013 4:13 am
Athou wrote:I mean your quote seems to be truncated
Ah, sorry, here's:
Message:
Level:
SEVERE
Stack Trace:
java.util.concurrent.FutureTask$Sync.innerGet(Unknown Source)
java.util.concurrent.FutureTask.get(Unknown Source)
be.hehehe.supersonic.service.Library$1.doInBackground(Library.java:181)
javax.swing.SwingWorker$1.call(Unknown Source)
java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
java.util.concurrent.FutureTask.run(Unknown Source)
javax.swing.SwingWorker.run(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
null
be.hehehe.supersonic.service.SubsonicService.invoke(SubsonicService.java:67)
be.hehehe.supersonic.service.SubsonicService.invoke(SubsonicService.java:43)
be.hehehe.supersonic.service.Library$1$1.call(Library.java:138)
Does Java support localization? I can help to translate interface into Russian if you want. Maybe others will also take part in other languages.
Rinaldus
Postby nicolaibvm » Mon Feb 11, 2013 2:20 pm
This looks like it could be a great player. I DO have one tiny little problem.
I cannot refresh my library. :(
The error I get in the log is this:
2013-02-11 15:19:50,737 ERROR [SupersonicException:22/SwingWorker-pool-4-thread-2]
javax.xml.bind.UnmarshalException
- with linked exception:
[org.xml.sax.SAXParseException; lineNumber: 207; columnNumber: 99; An invalid XML character (Unicode: 0x{2}) was found in the value of attribute "{1}" and element is "0".]
   at javax.xml.bind.helpers.AbstractUnmarshallerImpl.createUnmarshalException(Unknown Source)
   at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.createUnmarshalException(Unknown Source)
   at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(Unknown Source)
   at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal(Unknown Source)
   at be.hehehe.supersonic.service.SubsonicService.invoke(SubsonicService.java:60)
   at be.hehehe.supersonic.service.SubsonicService.invoke(SubsonicService.java:43)
   at be.hehehe.supersonic.service.Library.fetchAlbumList(Library.java:253)
   at be.hehehe.supersonic.service.Library.access$000(Library.java:45)
   at be.hehehe.supersonic.service.Library$1.doInBackground(Library.java:120)
   at javax.swing.SwingWorker$1.call(Unknown Source)
   at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
   at java.util.concurrent.FutureTask.run(Unknown Source)
   at javax.swing.SwingWorker.run(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
Caused by: org.xml.sax.SAXParseException; lineNumber: 207; columnNumber: 99; An invalid XML character (Unicode: 0x{2}) was found in the value of attribute "{1}" and element is "0".
   at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
   at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(Unknown Source)
   at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(Unknown Source)
   at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(Unknown Source)
   at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanAttributeValue(Unknown Source)
   at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanAttribute(Unknown Source)
   at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
   at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
   at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
   at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(Unknown Source)
   at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
   at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
   at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
   at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
   at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
   ... 15 more
2013-02-11 15:19:50,740 ERROR [SupersonicException:22/SwingWorker-pool-4-thread-2] Could not refresh library.
   at be.hehehe.supersonic.service.SubsonicService.invoke(SubsonicService.java:67)
Any ideas on how to fix this?
nicolaibvm
Previous
Return to Announcements
