4.7 beta
Re: 4.7 beta
Postby hakko » Thu May 17, 2012 11:03 am
I'd say the reason is that it reads meta-data (id3 tags) from all of your files. Yup, all 400.000. Then it stores that in a database for fast retrieval. The next time you scan your library (unless you move your files around on disk), it'll realize that the files are just the same as before and only read the ones you've added. It's an initial hit to make further use quicker.
MusicCabinet developer
hakko
Re: 4.7 beta
Postby taterb » Thu May 17, 2012 11:14 am
2nd the request for playlist import or info re: where the data is stored. has this functionality been moved into the database. newly created playlists aren't appearing in the file system ...
taterb
Re: 4.7 beta
Postby mesc » Thu May 17, 2012 11:33 am
hakko wrote:I'd say the reason is that it reads meta-data (id3 tags) from all of your files. Yup, all 400.000. Then it stores that in a database for fast retrieval. The next time you scan your library (unless you move your files around on disk), it'll realize that the files are just the same as before and only read the ones you've added. It's an initial hit to make further use quicker.
Ok I know it is scanning all the id3 tags... but I've seen tools doing the same in less time. Much less time. But ok I can't change this. Lets wait... thanks for the answer =)
mesc
Re: 4.7 beta
Postby GJ51 » Thu May 17, 2012 4:22 pm
The first scan takes the longest, but subsequent scans seem to go faster, although I haven't actually done any timing. Why aren't you just having it auto scan at a time when you know you won't be using it? The setting is now on the same screen with "Media Folders" at the bottom. I have "Fast access mode" set and it is smokin fast.
Re: 4.7 beta
Postby mesc » Fri May 18, 2012 2:42 pm
Mh 4.7b1 only shows ID3 Album names in , no Artist anymore? Why? Can I change this?
mesc
Re: 4.7 beta
Postby GJ51 » Fri May 18, 2012 4:16 pm
mesc wrote:Mh 4.7b1 only shows ID3 Album names in , no Artist anymore? Why? Can I change this?
I don't understand the question. Can you post a screen shot? I have always organized my library by \Music\Artist\Album\Track and made the folder names agree with the tags.
That may be why I don't see some of the other problems others are reporting.
Re: 4.7 beta
Postby GJ51 » Sat May 19, 2012 6:22 am
Anybody have Lyrics working?
Re: 4.7 beta
Postby Alsaya » Sat May 19, 2012 1:48 pm
Yeah, lyrics are working again, with some songs.
I sorted all my albums in the following structure
Band or singers name, for sorting reversed in name, first name
then I named the album dirctories "year - name - album title"
then the songs "01 - name - title" or "year - name - album titleCD1" for compilations
Now I've the albums sortet alphabetically, only the compilations still keep the year
and the cover art which was in the album folder and in each cd folder didn't show up
I'm aware that ID3 tags are now used but which one?
Therefore I'm looking for a possibility to select which ID3 tags are used and in which order
If someone has some suggestions?
Another strange behavoir
J. Geils Band runs now under J
Subsonic on Server 2012, only flac
Alsaya
Re: 4.7 beta
Postby jayw654 » Sat May 19, 2012 9:58 pm
Where's the Windows beta version?
jayw654
Re: 4.7 beta
Postby Alsaya » Sat May 19, 2012 10:12 pm
Alsaya
Re: 4.7 beta
Postby mohala » Sat May 19, 2012 10:49 pm
Could adding the ability to burn in subtitles when transcoding with mencoder or ffmpeg (if it is possible).
Also compatibility issues with the latest firefox it seams to either crash or slow down firefox 60% of the time.
Thanks.
Mo
mohala
Re: 4.7 beta
Postby GJ51 » Tue May 22, 2012 4:56 am
Firefox works fine on mine.
Re: 4.7 beta
Postby utopian » Tue May 22, 2012 10:45 am
just installed onto my Vm WHS2011 and working fine.. took a wee while to scan the folders but up n running :)
utopian
Re: 4.7 beta
Postby GJ51 » Thu May 24, 2012 1:09 am
The main screen refresh is still very annoying on a dark theme. There is still a persistent white flash just before the next set of Albums is redrawn. I think Ytechie may have made a post or two on some things he did to fix this back in ver 4.5.
I'd really like to see this fixed soon. Maybe even add some optional refresh styles, like sequentially rotating each Album cover at a set interval instead of just a wholesale redraw.
Re: 4.7 beta
Postby mesc » Thu May 24, 2012 9:10 am
Hej,
I have a strange freeze at night when Subsonic scans my media archive. The rescan is set up every night at 3:00. The PC freezes around 3:45 at position 30000. I changed back to latest stable v4.6 and all is fine again.
The whole computer freezes at this moment and i have to hard reset, after reboot Win XP tells me about heavy fail which occured. I also checked Windows event log but there is nothing listed.
Is there some debug feature which I could activate to see more detailed information in Subsonic log?
Thanks.
mesc
Return to Announcements
