Subsonic 4.0.beta1 released
Postby sindre_mehus » Wed May 05, 2010 6:28 pm
Thanks, got it. I see the same problem on my Subsonic server (Windows 7). However, it does not happen on some other m4a files I have for testing.
I'll look deeper into it.
Postby denisesballs » Wed May 05, 2010 6:30 pm
sindre_mehus wrote:Thanks, got it. I see the same problem on my Subsonic server (Windows 7). However, it does not happen on some other m4a files I have for testing.
Awesome thanks. I may have converted those myself from FLAC I believe.
denisesballs
Postby sindre_mehus » Wed May 05, 2010 6:50 pm
There is something odd with the file. I noticed that it's reported as "0 Kbps vbr" in Subsonic. If I do "Create AAC version" in iTunes, it produces an m4a file that streams properly.
Sorry, I don't think there is anything I can do about this, I'm out of ideas :?
Postby denisesballs » Wed May 05, 2010 6:56 pm
sindre_mehus wrote:There is something odd with the file. I noticed that it's reported as "0 Kbps vbr" in Subsonic. If I do "Create AAC version" in iTunes, it produces an m4a file that streams properly.
Ah ok. I see my other m4as are streaming properly. Must be something I did when I converted from FLAC. I found some MP3's I converted from FLAC and those play fine. Luckily I still have the FLACs and can try to reconvert. FWIW, those m4as that wont stream properly do play fine on the iPod.
Thanks again for the help.
denisesballs
Postby denisesballs » Wed May 05, 2010 7:25 pm
denisesballs
Postby sindre_mehus » Thu May 06, 2010 7:11 am
Ah, I love bugs when they are in other people's code :wink:
Postby denisesballs » Thu May 06, 2010 8:44 pm
Hey Sindre, are licenses from 3.x not gonna work for 4.x? 4.0.beta2 is saying "Invalid license key." for mine.
denisesballs
Postby sindre_mehus » Thu May 06, 2010 8:48 pm
Yeah, they should work. Pls double-check that you're entering it correctly.
Postby denisesballs » Thu May 06, 2010 8:50 pm
sindre_mehus wrote:Yeah, they should work. Pls double-check that you're entering it correctly.
Yeah tried it multiple times in different browsers.
denisesballs
Postby sindre_mehus » Fri May 07, 2010 2:10 pm
I just emailed you the license key again. Also tried it on my 4.0.beta2 test server and it works.
WAV Transcoding won't play anymore.
Postby draxcileon » Thu May 13, 2010 2:42 am
Hi Sindre! Thanks for your continued effort in the development of this fine program. That being said, I need some help.
I upgraded to 4.0, and now my wav files won't play all the way through. :? The file begins and plays for about a half a second, then the position cursor in the player skips all the way to the end and play stops. I'm using windows 7. Any suggestion?
draxcileon
Previous
Return to Announcements
