Any plans for SSL support?
Thank you.
ff
pej1025 wrote:getting the same "parameter" error as the other guys.
flacflac wrote:Any plans for SSL support?
Thank you.
ff
pej1025 wrote:yep, that version fixed the parameter errors. back to my original problem with the downloads though. i can right click an album in the right pane and click download, choose my location, but it immediately says download complete. size of the zip is 4.00KB
jmechy wrote:I can connect to my subsonic server fine via the web interface, but can't seem to get subAir to work.
I've downloaded the latest version, put in my username and password, and entered the IP address of the server. The clock spins as if the program is thinking, but nothing ever happens. I've tried using the admin user as well as another user I've created with the same results. I've also tried connecting directly via the IP, as well as my .subsonic.org address.
Am I missing something stupid?
pha9992001 wrote:Oh, another note on the address, the http:// is required for the server address field.
NonooStar wrote:I have the same problem.
I can log through the web interface or via the SubSonic app on Android, but SubAir doesn't work. I put my username, password and address but nothing happens when i click on Save Settings.
I tried to uninstall SubAir to install previous versions which worked and they doesn't work anymore.
