Pathduck wrote:Coolio
Hope it's fixed the "various artists" bug? Can you guys check?
Pathduck wrote:@Madevil, does your modification work with the WAR file version? I run on Jboss and use just the .war.
2012-09-12 20:29:29,418 INFO [org.jboss.as.osgi] (MSC service thread 1-4) JBAS011907: Register module: Module "deployment.subsonic.war:main" from Service Module Loader
2012-09-12 20:29:32,702 ERROR [org.apache.catalina.core.StandardContext] (MSC service thread 1-1) Error listenerStart
2012-09-12 20:29:32,702 ERROR [org.apache.catalina.core.StandardContext] (MSC service thread 1-1) Context [/subsonic] startup failed due to previous errors
2012-09-12 20:29:32,735 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-1) MSC00001: Failed to start service jboss.web.deployment.default-host./subsonic: org.jboss.msc.service.StartException in service jboss.web.deployment.default-host./subsonic: JBAS018040: Failed to start context
at org.jboss.as.web.deployment.WebDeploymentService.start(WebDeploymentService.java:95)
at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1811) [jboss-msc-1.0.2.GA.jar:1.0.2.GA]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1746) [jboss-msc-1.0.2.GA.jar:1.0.2.GA]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110) [rt.jar:1.6.0_18]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603) [rt.jar:1.6.0_18]
at java.lang.Thread.run(Thread.java:636) [rt.jar:1.6.0_18]
2012-09-12 20:29:32,957 INFO [org.jboss.as.server] (ServerService Thread Pool -- 28) JBAS018559: Deployed "subsonic.war"
2012-09-12 20:29:32,960 INFO [org.jboss.as.controller] (Controller Boot Thread) JBAS014774: Service status report
JBAS014777: Services which failed to start: service jboss.web.deployment.default-host./subsonic: org.jboss.msc.service.StartException in service jboss.web.deployment.default-host./subsonic: JBAS018040: Failed to start context
Pathduck wrote:I've tested Madevil's Mashupmod, but it throws an error during deployment
- Code: Select all
However, probably something which should be possible to have a look at over time to have it work on Jboss too.
I
Pathduck wrote:@Hakko you have very nice taste in music; Mirah, MBMA, Moldy Peaches, Monsta Island, very eclectic
but some abuse the privilege!DaveWut wrote:I had like 2 or more problems with the database. My database was corrupted two times, the entire website was down because of it and I still don't know exactly why it is doing this. Seriously, like hakko said, this needs to be changed.
