Windows 8 client
Re: Windows 8 client
Postby andyoak » Thu May 30, 2013 9:09 am
rob63 wrote:Hi,
I'm running plain vanilla Subsonic 4.8. It connects to demo server fine but getting "a connection attempt failed because the connected party did not properly respond after a period of time, ... when trying to
connect to my server. Not using SSL. No issues connecting using same parameters with browser or remote app.
if you are running the server on the same machine (localhost) then this should be your problem http://stackoverflow.com/a/14089311/251539
To overcome this just open the command line and run "CheckNetIsolation.exe LoopbackExempt –a –n=61993AndreCarvalho.Supersonic_ds8y2a6qr665m"
andyoak
Postby rob63 » Thu May 30, 2013 12:55 pm
I copied/pasted into the command prompt but it returned with invalid parameters. I will test out again if you can update the widget so that it works properly on the localhost without undue user changes.
Thanks.
andyoak wrote:
rob63 wrote:Hi,
rob63
Postby andyoak » Thu May 30, 2013 4:24 pm
Try this: after pasting in the command line window, delete the dashes "-" and add them again. Worked for me :) Some encoding must be happening I guess.
andyoak
Postby kulpae » Mon Jul 15, 2013 1:46 pm
I like the app and its look and feel, but it doesn't play music. My library is compressed with FLAC entirely. I'm transcoding it to mp3 with this:
step 1: flac --silent --decode --stdout %s
step 2: lame --silent -h -b %b -
it works on my phone and the JW Player in the web view (switching to the default transcoding didn't help).
In the LocalState\MetroLogs there are no log files.
The slider stays at 0 (showing 0 while dragged) and doesn't move.
Otherwise all the meta data (cover image, name, duration, etc. are shown correctly)
thx
ps: I'm also using a non-default port. In the login view I appended it to the server address with a colon before. (e.g. serverna.me:8080)
kulpae
Postby greenleaved » Thu Aug 22, 2013 1:38 pm
Is there any way to randomize the playlist? Am I missing it? If not, we should get that.
Great app. Thanks a lot.
greenleaved
Previous
Return to Announcements
