Subsonic 4.9.beta2 released
Re: Subsonic 4.9.beta2 released
Postby PieterB » Sat Nov 23, 2013 1:40 pm
My (unanswered) previous question/remark remains: in earlier versions - way back - a picture (jpg, png) in a folder containing for instance two sub-folders, CD1 and CD2 would be shown.
In later versions, that very nice feature disappeared, and a picture is only shown if the folder contains music files.
Is there any possibility to bring that feature back to the current release?
Thanks for looking into this matter!
PB
PieterB
Postby PieterB » Sat Nov 23, 2013 8:08 pm
I just noticed that tag information - when files are in APE format, is NOT read at all. If I convert those files to FLAC, the tag information is read fully and correctly.
Will this be an issue with the 4.9 release?
PB
PieterB
Postby mchyde » Mon Nov 25, 2013 2:13 am
Is it possible to do away with the play next/last pop-up? I like it the way it was before, and don't mind moving a song in the playlist need to. Having to select next or last each time is annoying, especially when creating a huge list. It took me a while to figure out what the little box was that keeps popping up every time I clicked on the plus sign. It wasn't until I hovered over it that the text became visible.
mchyde
Postby noxon » Mon Nov 25, 2013 6:10 pm
Better yet, add a new button for "play next" - the popup is annoying when trying to add multiple tracks quickly...
noxon
Postby mikekay » Tue Nov 26, 2013 6:21 pm
Im really close to getting it out of there, can someone give me the original playadddownload.jsp?
Should be located in:
C:\subsonic\jetty\3636\webapp\WEB-INF\jsp
mikekay
Postby mikekay » Tue Nov 26, 2013 6:47 pm
See tips section for how to remove will post a tut / tip / trick on how to modify the playadddownload.jsp
mikekay
Postby sindre_mehus » Tue Nov 26, 2013 8:41 pm
noxon wrote:Better yet, add a new button for "play next" - the popup is annoying when trying to add multiple tracks quickly...
I'm gonna replace the Download button, and have two separate buttons for "Play next" and "Play last".
Postby rubbersoul » Wed Nov 27, 2013 4:09 pm
Is there any place we can look at feature requests that are being worked on/considered/have been denied? I'm wondering if there is any plan to add additional views for browsing the library, like browse by year, decade, genre, artist, album, rating, folder structure, etc. I personally like to quickly get to albums that have been released this year, which doesn't necessarily correspond to being most recently added to my library, but I'm sure everyone does it differently and would appreciate the flexibility.
Thanks for the update!
rubbersoul
Postby bile » Thu Nov 28, 2013 4:19 am
Has the issue with tracks starting with numbers get stripped and used as the track number been fixed? Like Nine Inch Nails Ghosts I-IV album?
bile
Postby nildin » Thu Nov 28, 2013 10:25 am
Tried 4.9 beta2 and I have a problem with transcoding on Firefox.
Everytime I try to play a flac or avi file and subsonic needs to transcode stuff the flashplugin in Firefox crashes.
I tried it with Internet Explorer and it works just fine.
Client:
Win 7 64
Firefox 25.0.1
Flash 11.9.900.152
Server:
Debian Wheezy
Oracle java 1.7.0_45
nildin
Postby bjack003 » Sat Nov 30, 2013 6:53 am
I like the new update, thanks
I would like to report the following error when clicking on Settings > Personal and Settings > Users (running on Ubuntu 13.10, Tomcat 7.0.42, Java 1.7.0_25(OpenJDK), Subsonic 4.9beta2)
Exception   org.apache.jasper.JasperException
Message   /WEB-INF/jsp/personalSettings.jsp (line: 37, column: 20) "${default}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${default}]
Java version   Oracle Corporation 1.7.0_25
Operating system   Linux 3.11.0-13-generic
Server   Apache Tomcat/7.0.42
Memory   Used 112 of 269 MB
Stack trace   org.apache.jasper.JasperException: /WEB-INF/jsp/personalSettings.jsp (line: 37, column: 20) "${default}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${default}]
   at org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:42)
   at org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:443)
   at org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:199)
   at org.apache.jasper.compiler.Validator$ValidateVisitor.checkXmlAttributes(Validator.java:1223)
   at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:875)
   at org.apache.jasper.compiler.Node$CustomTag.accept(Node.java:1539)
   at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2376)
   at org.apache.jasper.compiler.Node$Visitor.visitBody(Node.java:2428)
   at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:894)
   at org.apache.jasper.compiler.Node$Visitor.visit(Node.java:2434)
   at org.apache.jasper.compiler.Node$Root.accept(Node.java:475)
   at org.apache.jasper.compiler.Validator.validateExDirectives(Validator.java:1798)
   at org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:217)
   at org.apache.jasper.compiler.Compiler.compile(Compiler.java:373)
   at org.apache.jasper.compiler.Compiler.compile(Compiler.java:353)
   at org.apache.jasper.compiler.Compiler.compile(Compiler.java:340)
   at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:646)
   at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:357)
   at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390)
   at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
   at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
   at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:749)
   at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:487)
   at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:412)
   at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:339)
   at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236)
   at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257)
   at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183)
   at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
   at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
   at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
   at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
   at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
   at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
   at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
   at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
   at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
   at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
   at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
   at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
   at java.lang.Thread.run(Thread.java:724)
Error
Message   /WEB-INF/jsp/userSettings.jsp (line: 122, column: 4) "${not command.new and not command.admin}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${not command.new and not command.admin}]
Memory   Used 119 of 269 MB
Stack trace   org.apache.jasper.JasperException: /WEB-INF/jsp/userSettings.jsp (line: 122, column: 4) "${not command.new and not command.admin}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${not command.new and not command.admin}]
bjack003
Postby sindre_mehus » Sat Nov 30, 2013 11:04 am
[quote="bjack003"]I like the new update, thanks
Thanks for reporting it - will be fixed.
Postby bile » Sat Nov 30, 2013 6:17 pm
Can you please address the issue with stripping integers from the beginning of track names? It ruins submissions to last.fm and makes it difficult to see what's playing.
"01 Ghosts I" is the track name for NIN Ghosts I - IV for example. It gets changed to "Ghosts I"
bile
Postby DaveWut » Tue Dec 03, 2013 6:02 pm
Is this has been issued?
DaveWut
Re: Subsonic 4.9.beta2 and editing pages
Postby lbvagrant » Wed Dec 04, 2013 9:51 am
iv had the top and right pane modified for a few years now and with the new beta I cannot see where the page is being generated from
to explain the file that I normally edit is C:\subsonic\jetty\3636\webapp\WEB-INF\jsp\top.jsp and right.jsp
well this time I changed those pages and its not effecting the site?
I "view source" in internet explorer and its not the same page that's in the folder above?
so did I miss something or did things do the ole switcheroo on me?
:cry:
thnx for any info on this as my clock, news and weather are missing from my page
Sent: Thu Apr 25, 2013 12:51 am
To: lbvagrant
oh boy you are one pathetic egoistic idiot.
wow someone cant deal with a NO
lbvagrant
Return to Announcements
