joelbrave wrote:testing DLNA connectivity to Subsonic, so far I'm only able to see and play audio files, and only see folders containing audio files.
Is that a bug or is that the way it is intended for the initial release?
- Joel
PieterB wrote:My (unanswered) previous question/remark remains: in earlier versions - way back - a picture (jpg, png) in a folder containing for instance two sub-folders, CD1 and CD2 would be shown.
In later versions, that very nice feature disappeared, and a picture is only shown if the folder contains music files.
Is there any possibility to bring that feature back to the current release?
Thanks for looking into this matter!
daneren2005 wrote:I saw you create a Beta3 in the source code, so I thought you would be doing another release and went ahead and updated. Either way, I guess I'll post my findings here instead so I don't forget them. In Firefox on Windows, the Recently Added listings now are just in a long (and I mean very long) vertical list instead of a grid. Also, I am getting errors that the browser can't load the new fonts you are referencing because they are under http while my server is https. Can you please add a switch that loads the fonts from the https link if the session is in https?
Exception org.apache.jasper.JasperException
Message /WEB-INF/jsp/userSettings.jsp (line: 122, column: 4) "${not command.new and not command.admin}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${not command.new and not command.admin}]
Java version Oracle Corporation 1.7.0_25
Operating system Linux 3.8.0-29-generic
Server Apache Tomcat/7.0.26
Memory Used 32 of 45 MB
Stack trace org.apache.jasper.JasperException: /WEB-INF/jsp/userSettings.jsp (line: 122, column: 4) "${not command.new and not command.admin}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${not command.new and not command.admin}] at org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:42) at org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:408) at org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:199) at org.apache.jasper.compiler.Validator$ValidateVisitor.checkXmlAttributes(Validator.java:1218) at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:870) at org.apache.jasper.compiler.Node$CustomTag.accept(Node.java:1539) at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2376) at org.apache.jasper.compiler.Node$Visitor.visitBody(Node.java:2428) at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:889) at org.apache.jasper.compiler.Node$CustomTag.accept(Node.java:1539) at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2376) at org.apache.jasper.compiler.Node$Visitor.visitBody(Node.java:2428) at org.apache.jasper.compiler.Node$Visitor.visit(Node.java:2434) at org.apache.jasper.compiler.Node$Root.accept(Node.java:475) at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2376) at org.apache.jasper.compiler.Validator.validateExDirectives(Validator.java:1790) at org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:217) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:373) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:353) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:340) at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:646) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:357) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:684) at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:471) at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:402) at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:329) at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236) at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257) at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:807) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501) at javax.servlet.http.HttpServlet.service(HttpServlet.java:621) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:166) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:173) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:43) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:54) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:54) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:987) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579) at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1805) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:724)
HerrNilsson wrote:Hi,
Installing a new machine with Tomcat 7.0.26, Subosnic 4.9 Beta 2 on an Ubuntu Server 12.04.3 LTS with java version "1.7.0_25".
OpenJDK Runtime Environment (IcedTea 2.3.10) (7u25-2.3.10-1ubuntu0.12.04.2)
OpenJDK 64-Bit Server VM (build 23.7-b01, mixed mode)
Most of it works, but when i click "Change administrator password" after the login i get the error message below
- Code: Select all
Anyone know what to do? Thanks!
sindre_mehus wrote:HerrNilsson wrote:Hi,
- Code: Select all
This has been fixed for the next beta (soon to be released). It happens only when deploying on Tomcat 7, by the way.
Kind regards
HippopoKiboko wrote:The download function still not working...
viewtopic.php?f=2&t=1424&start=15#p59187
This should work in 4.9.beta3. If not, could you please send me an example file?
