madsenmi wrote:I agree with everyone that beta4 is another step in the right direction however I am still having an issue whenever a user downloads a video file from me it is automatically zipped. Would love to see this removed as this was not a regular function in 4.8 and below.
<c:if test="${param.asTable}"><td></c:if>
<c:if test="${(empty param.downloadEnabled or param.downloadEnabled)}">
<a href="/subsonic/download.view?id=${param.id}">
<img src="<spring:theme code="downloadImage"/>" alt="<fmt:message key="common.download"/>"
title="<fmt:message key="common.download"/>"></a>
</c:if>
<c:if test="${param.asTable}"></td></c:if>
[2014-01-06 03:45:46,143] WARN JaudiotaggerParser - Error when parsing tags in <pathToFile> - see subsonic.err for full details
[2014-01-06 03:48:41,412] WARN JaudiotaggerParser - Error when parsing tags in <pathToFile> - see subsonic.err for full details
org.jaudiotagger.audio.exceptions.CannotReadException: Unable to read file because it is too small to be valid audio file: <pathToFile>
at org.jaudiotagger.audio.generic.AudioFileReader.read(AudioFileReader.java:90)
at org.jaudiotagger.audio.AudioFileIO.readFile(AudioFileIO.java:285)
at org.jaudiotagger.audio.AudioFileIO.read(AudioFileIO.java:148)
at net.sourceforge.subsonic.service.metadata.JaudiotaggerParser.getRawMetaData(JaudiotaggerParser.java:74)
at net.sourceforge.subsonic.service.metadata.MetaDataParser.getMetaData(MetaDataParser.java:47)
at net.sourceforge.subsonic.service.MediaFileService.createMediaFile(MediaFileService.java:436)
at net.sourceforge.subsonic.service.MediaFileService.checkLastModified(MediaFileService.java:127)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:197)
at net.sourceforge.subsonic.service.MediaScannerService.scanFile(MediaScannerService.java:228)
at net.sourceforge.subsonic.service.MediaScannerService.scanFile(MediaScannerService.java:232)
at net.sourceforge.subsonic.service.MediaScannerService.doScanLibrary(MediaScannerService.java:178)
at net.sourceforge.subsonic.service.MediaScannerService.access$000(MediaScannerService.java:48)
at net.sourceforge.subsonic.service.MediaScannerService$2.run(MediaScannerService.java:147)
baaldemon wrote:Definitely a move back in the right direction with the download function. However there is still a horrible user workflow to download a single song, especially coming from previous versions where this action was a single click. The top download link is called "Download" not "Download All" which is the functionality that it actually provides. This once again is still rather confusing for the end user and leaves them in a state of questioning when trying to download a single file as there is no clear design that shows them how to do this. It seems like there is more than enough space to accomodate 4 buttons rather than just 3, meaning you could continue to have a download button even while adding the play next. Is there a reason why you are pushing so hard to remove the basic one click single file download functionality when it seems you can keep this while adding the new functionality that you are trying to put in place?
