Subsonic 5.0 released
Postby sindre_mehus » Sun Sep 21, 2014 8:23 pm
Hi there!
Subsonic 5.0 is now released with these bug fixes since the last beta:
Bugfix: Use UTF-8 encoding for filenames in ZIP archives. (Requires Java 7+)
Bugfix: Fixed problem with unresponsive dialogs in web interface.
Bugfix: Use 2000 kbps as default video bitrate.
Bugfix: Sort playlists alphabetically.
Bugfix: Fixed some sorting issues (e.g., for same artist found in multiple media folders).
Bugfix: Make password recovery work with https.
Take care,
Re: Subsonic 5.0 released
Postby OlYeller21 » Sun Sep 21, 2014 11:27 pm
Thanks, Sindre!
OlYeller21
Postby bruhja » Mon Sep 22, 2014 3:21 am
Awesome! :D
bruhja
Postby xtxer » Mon Sep 22, 2014 4:10 pm
thanks for acknowledging and fixing the default video bit rate so quickly.
subsonic is a daily part of my life, and many of my friends' and family's lives too, so thank you very much for the work that you do!
xtxer
Postby kargath » Tue Sep 23, 2014 6:49 pm
The directory sort bug still persists. I confirm the option "sort albums by year" is unchecked. I'm pretty sure I've figured out the condition that causes it...
I end up with two groups of alphabetically sorted directories. The first set only has another set of directories nested in it.
The second set has directories plus some individual files that for one reason or another belong in the root of that directory.
Does that make sense?
For whatever reason, subsonic isn't just sorting the directories in order, but also looking inside of them and if there's any files then it groups that set of directories together.
Example:
If I have this directory structure,
A1/X1/files
A1/X2/files
A1/files
A2/X1/files
A3/X1/files
A3/files
A4/X1/files
A4/X2/files
Subsonic orders it like this,
A2
A4
A1
A3
This is a weird and undesired behavior.
Can someone else that's having this issue please confirm as well?
kargath
Postby samy4972 » Thu Sep 25, 2014 9:56 am
Thks Sindre.
Just one thing. Sometimes, when I am on a album page, the auto refresh brings me back to the home page.
Someone else ?
Thks.
samy4972
Postby kargath » Thu Sep 25, 2014 12:18 pm
samy4972 wrote:Thks Sindre.
Someone else ?
Thks.
Pretty sure that's the default "timeout" behavior and has been for quite a long time.
Unless you mean while you're actually playing music. I don't think I've had that happen.
kargath
Postby HippopoKiboko » Thu Sep 25, 2014 2:21 pm
http://forum.subsonic.org/forum/viewtopic.php?f=2&t=1424&p=64505#p64505
Thanks, working excellent!
HippopoKiboko
Postby samy4972 » Fri Sep 26, 2014 7:12 am
Someone else ?
Thks.
I think it was when I played...
Test....
Thks ;)
samy4972
Postby kdistin » Fri Sep 26, 2014 6:56 pm
Your release notes say:
However on the Android app I still see multiple entries for the same artist.
I have deleted all the settings on the app and reconfigured the server to make sure nothing was cached.
Can I provide you with any more information to help you fix this?
Keith
kdistin
Postby sindre_mehus » Sat Sep 27, 2014 10:51 am
kargath wrote:The directory sort bug still persists. I confirm the option "sort albums by year" is unchecked. I'm pretty sure I've figured out the condition that causes it...
Example:
A1/X1/files
A1/X2/files
A1/files
A2/X1/files
A3/X1/files
A3/files
A4/X1/files
A4/X2/files
A2
A4
A1
A3
Well, this behaviour is at least intentional. Subsonic differentiates between "albums" and "directories" (an album is a directory with at least one song in it), and the sorting algorithm puts directories before albums. In your example, A1 and A3 are classified as albums and hence come last.
Of course, if most people think this is an undesired behavior I'll be glad to change it.
Any opinions?
Postby kargath » Mon Sep 29, 2014 12:29 am
Example:
A1/X1/files
A1/X2/files
A1/files
A2/X1/files
A3/X1/files
A3/files
A4/X1/files
A4/X2/files
A2
A4
A1
A3
Any opinions?
Within the say, A1 directory, I'd agree that I want folders first, then files.
When the sorting all of the directories in the root directory, I don't understand why subsonic is "looking into" each of those directories prior to sorting them.
This seems odd...
Certain artists may have one off songs that I didn't want to put in a folder, or other files associated with the artist that aren't songs or aren't album specific.
Subsonic didn't always sort the folders like this. I feel like this started when you added the metadata sorting.
kargath
Postby mitrailer » Mon Sep 29, 2014 6:28 pm
In the Artist field, the alphabetical order of the accented (or umlauted) characters is wrong. For example, the correct order for the list below is:
SebastiAn
Sebastien Grainger
Sébastien Léger
Sébastien Schuller
Sébastien Tellier
Secret Machines
The Section Quartet
System of a Down
Systema Solar
But in Subsonic is listed like:
SebastiAn
Sebastien Grainger
Secret Machines
The Section Quartet
System of a Down
Systema Solar
Sébastien Léger
Sébastien Schuller
Sébastien Tellier
This behavior is also present in the playlist.
I am aware of the group Index in the Seting->Index tab, e.g., A(AÂÀÁ), but this setting only accounts for the first letter, however the second one (and I belive the third one too) is not in the correct alphabetic position. Could it be possible to correct this behaviour. Cheers to all
mitrailer
Postby sindre_mehus » Mon Sep 29, 2014 8:15 pm
kargath wrote:
sindre_mehus wrote:
A1/X1/files
A1/X2/files
A1/files
A2/X1/files
A3/X1/files
A3/files
A4/X1/files
A4/X2/files
A2
A4
A1
A3
Any opinions?
This seems odd...
Sorry, I misunderstood and thought this was below the root level. But if I try your example on the root (artist) level, I get the correct order (A1, A2, A3, A4).
If possible, could you create an account for me on your server so I can take a look?
Postby fonsoy » Wed Oct 01, 2014 10:53 am
Dear Sindre,
I am looking up to a weird bug in the left frame in the newest release.
The frame shows the 900-1100 top results, and cuts off the remaining folders (in my case only 'all folders' contain enough results to achieve this).
I can only scroll up to artists with J, at which the list ends. This issue has been seen on Chrome, Safari and Internet Explorer. I tried clearing the cache and using other systems, but it didn't help.
fonsoy
Return to Announcements
