Subsonic 5.2 released
Re: Subsonic 5.2 released
Postby sindre_mehus » Wed Mar 04, 2015 7:45 pm
Please notice that a 5.2.1 bugfix release is now available: viewtopic.php?f=4&t=15368
Postby jonpca » Wed Mar 11, 2015 2:51 pm
Hello. I've had the same problem with 5.1, 5.2 and 5.2.1. So I've gone back to 5.0, although doing so seemed to break my database, but I think that is sorted now. I'm on WHS v1 and I note you are on Windows Server 2008 - could there be a connection. Although I know of another user on WHS v1 who hasn't had this problem. Perhaps we have the same router - I have an Asus RT-N66U? Cheers
rafael.nieves72 wrote:This upgrade disabled the port forward feature somehow.
I though it was a router issue .But even if i disable the firewall, i still can't connect.I used the port open tool.And it's showing that the port is open.I have to go back to last version till this gets fixed.
I'm on windows server 2008.
jonpca
Postby sindre_mehus » Wed Mar 11, 2015 8:11 pm
jonpca wrote:Hello. I've had the same problem with 5.1, 5.2 and 5.2.1. So I've gone back to 5.0, although doing so seemed to break my database, but I think that is sorted now. I'm on WHS v1 and I note you are on Windows Server 2008 - could there be a connection. Although I know of another user on WHS v1 who hasn't had this problem. Perhaps we have the same router - I have an Asus RT-N66U? Cheers
Most likely it's an issue with Windows Firewall. Starting with version 5.1, I made a change to make it work properly with "Windows Firewall with Advanced Security". Maybe this doesn't work properly with WHS and Windows Server 2008. So you could try to manually configure the firewall and see if that helps.
Previous
Return to Announcements
