Subsonic 5.3.beta2 released
Re: Subsonic 5.3.beta2 released
Postby lajuice » Tue Sep 29, 2015 1:07 am
can there be an option to Hide left frame by default, added toggle button..... please
lajuice
Postby IdiotProof » Mon Oct 05, 2015 6:20 am
Is there an option to show the left panel ? I've a 4k monitor with ton of place. At least when login in admin, I understand to mask it in user mode but it's painful in admin mode
IdiotProof
Postby HighCast » Mon Oct 05, 2015 8:39 pm
Also this issue would be fancy to get fixed.
This happens especially when using *.subsonic.org redirection.
viewtopic.php?f=8&t=15997
//Highcast
HighCast
Postby changelin » Wed Oct 14, 2015 9:58 pm
On Windows 10 Pro I've noticed that only about 1 out of 4 reboots will Subsonic turn green and the server will start. When it's red the server will not start. Even if I go into the SS control panel and click the button to force start. Everything worked find on Win 7, 8 and 8.1. Could there be something in Win 10 that is preventing it from starting?
Edit: I just rebooted and got the red icon. Below is my log file (minus my ports).
[2015-10-14 18:42:22,786] INFO HsqlDaoHelper - Checking database schema.
[2015-10-14 18:42:27,132] INFO HsqlDaoHelper - Done checking database schema.
[2015-10-14 18:42:29,523] INFO SettingsService - Java: 1.8.0_60, OS: Windows 10
[2015-10-14 18:42:29,585] INFO VersionService - Resolved local Subsonic version to: 5.3.beta2
[2015-10-14 18:42:29,835] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Thu Oct 15 03:00:00 CDT 2015
[2015-10-14 18:42:29,898] INFO UPnPService - Starting UPnP service...
[2015-10-14 18:42:29,960] INFO PodcastService - Automatic Podcast update disabled.
[2015-10-14 18:42:30,054] INFO UPnPService - Disabling UPnP/DLNA media server
[2015-10-14 18:42:30,054] INFO UPnPService - Starting UPnP service - Done!
[2015-10-14 18:42:39,941] INFO NetworkService - Successfully forwarding port XXXX and port XXXX.
Edit 2: I checked Widows services and the service had not started. When I try to manually start the service I get the error "Windows could not start the Subsonic service on Local Computer. Error 1067 The process terminated unexpectedly. "
changelin
Postby FUNTOWNE » Fri Oct 23, 2015 3:58 pm
Adding another vote to enable/disable the autohide of the left hamburger menu.
FUNTOWNE
Postby Schnip » Sat Dec 19, 2015 3:45 am
If you want to avoid flash, you can try my HTML5 Player modification:
viewtopic.php?f=6&t=16239&p=69649
Schnip
Previous
Return to Announcements
