Subsonic 5.3 final released
Postby jmoonen » Mon Oct 26, 2015 9:11 pm
I see that "hide left frame by default, added toggle button" is turned off.
Are there more changes sindre ?
jmoonen
Re: Subsonic 5.3 final released
Postby lajuice » Mon Oct 26, 2015 11:12 pm
sindre,
Just downloaded the new release and as always great work ... thank you for the left frame on by default and added toggle button greatly appreciated.
Keep up the good work ...I will let you know how it goes
lajuice
Postby jayw654 » Tue Oct 27, 2015 12:44 am
In windows 10 x64 fresh install with latest version of java version 8, Subsonic 5.3 will not list the music. Subsonic will scan and see that music is in the folder but no list, Please fix!
jayw654
Postby daneren2005 » Tue Oct 27, 2015 4:57 pm
PSA to those using DSub (or any client which supports it) when using the Browse By Tags option: it will show as no data until a new scan is run. If you update and it looks like there is nothing there simply run a manual scan and refresh and it will fix nothing showing up.
Postby theast » Tue Oct 27, 2015 6:40 pm
Since upgrading to 5.3, trying to use either external player option will give me a playlist that only uses my local IP, not my external IP in the M3U. Great for streaming on the LAN, but not over the Internet :) I looked through the options, didn't seem to find anything that had changed to produce this behavior. The web player works just fine. Anybody else experiencing this?
PS - loyal SS user for over 4 years now, thank you for all the hard work you do!
E
theast
Postby Nico » Wed Oct 28, 2015 8:42 pm
jmoonen wrote:I see that "hide left frame by default, added toggle button" is turned off.
http://www.subsonic.org/pages/changelog.jsp
Nico
Postby jeffgt14 » Thu Oct 29, 2015 1:50 pm
Any reason when I try to install in Ubuntu it warns me about the package being “Bad Quality”?
jeffgt14
Postby grumpwagon » Thu Oct 29, 2015 7:40 pm
It's been that way forever. He just doesn't include some metadata in the package that Ubuntu wants. You can safely ignore the warning.
grumpwagon
Postby zeroth » Fri Oct 30, 2015 11:15 am
My upgrade went off without an hitch on windows and standalone linux. I use the standalone version for movies but there is not way to select or change cover art. This makes the interface look less than appealing. Can anyone confirm that this is correct for 5.3 with movies. Seems odd to not have a way to edit cover art. If there is something wrong then I would like to know so I can work to address the issue.
By the way, if this is correct....PLEASE BRING BACK THAT FEATURE!!!!
zeroth
Postby SparkyRih » Fri Oct 30, 2015 8:26 pm
Finally custom URL support, after all these years... No more workarounds...
VMWare ESXi 5.5 > Ubuntu 16.04 > Subsonic 6.0 (Modded with PHP based registration feature)
SparkyRih
Postby baxtr » Sat Oct 31, 2015 2:14 am
win 10 upgraded fine....show sidebar by default Awesome....Thanks Sindre
baxtr
Postby langtall » Sat Oct 31, 2015 1:12 pm
Before the update, maps with submaps and files wouldn'T show in the list directly, but underneath the list. Now they are not shown at all?
langtall
Postby degan6 » Wed Nov 04, 2015 8:37 am
Whats the point of the custom URL? To my understanding and experience Subsonic as always supported this. I have had a record from my domain pointed to my subsonic install for years and never had a problem connecting the too.
I don't understand what this feature does that subsonic could not already do.
degan6
Postby Jebba » Sat Nov 07, 2015 8:55 pm
degan6 wrote:Whats the point of the custom URL? To my understanding and experience Subsonic as always supported this. I have had a record from my domain pointed to my subsonic install for years and never had a problem connecting the too.
Same here :)
Jebba
Postby FirstTracks » Mon Nov 09, 2015 3:55 pm
With this upgrade my album count inexplicably went from >4K to just over 3K. However, the number of artists and songs, as well as disk space and total hours remained consistent.
FirstTracks
Return to Announcements
