Subsonic Demo Server
Postby sindre_mehus » Thu Feb 26, 2009 5:54 pm
I just set up a Subsonic demo server.
Please check out http://subsonic.sourceforge.net/demo.php and let me know what you think.
hi
Postby buellie » Thu Feb 26, 2009 11:21 pm
pretty cool..i like the part where u disable the settings...id like to be able to do that too....
buellie
Re: hi
Postby sindre_mehus » Fri Feb 27, 2009 9:58 am
buellie wrote:pretty cool..i like the part where u disable the settings...id like to be able to do that too....
Yep, that will be possible to do in Subsonic 3.7
Postby kapz » Mon Mar 02, 2009 8:10 pm
Ah, nice the settings are gone. I've been modifying the jsp files to remove the setting if the user is unable to stream. It looks like support to remove the settings link in the playlist won't work for me though.
Thx sindre
Paid Subsonic user
Love my unRaid (~9.5TB): [url=http://lime-technology.com/forum/index.php?topic=2031.msg40351#msg40351]Pictures Here (Reply #82)[/url]
kapz
Postby oxide[NL] » Fri Jul 10, 2009 3:21 pm
public viewable ip addresses from " guests" isnt that a security risk ?
oxide[NL]
Postby sindre_mehus » Mon Jul 13, 2009 6:38 am
I'll remove the IPs. Thanks for pointing it out.
Postby nicotitineh » Tue Aug 17, 2010 10:02 pm
Hi there. Old topic but seems to be the good place for a question.
I use the soft for about 2years now not like a mp3 streamer but for his indexing an search engine which are great for people to know which mp3 I have.
And know I'm "tired" to create account each time a new user tell me.
so if u have tricks, tips or tuto to help me make access like the demo one where setting button isn't and guest may come like they want...
naively I think that kind of url will works but no:
http://mysubsonicserver/search.view?use ... word=guest
Hope my english is not too bad and understandable.
If someone may bring me an answer will be cool.
nicotitineh
Postby sindre_mehus » Wed Aug 18, 2010 8:13 am
Change search.view to login.view in your url and it should work.
Postby nicotitineh » Wed Aug 18, 2010 8:18 am
sindre_mehus wrote:Change search.view to login.view in your url and it should work.
ya it works; thx :)
And forget about setting question I update (i was still on 3.6) and the option is integrated in new version.
thx for answer
nicotitineh
Postby nicotitineh » Wed Aug 18, 2010 9:33 am
I'm back :lol:
Is there a way to have the 3.6 search into the 4.0.1
cause my files are not really tagged and it doesn't find like before.
to explain what I mean, for exemple with your demo when u make search with those 2 words (into the ANY textbox): "bilk Alles" it gives 0 answer (but there well a trax from "bilk" which this name "alles") and the 3.6 were finding directly the files I think.
nicotitineh
Demo Server
Postby JesterEE » Thu Nov 11, 2010 3:32 pm
Sindre,
I have been using Subsonic for a few months now and really enjoy your efforts.
I noticed that the demo server you have for the site (http://subsonic.org/demo/) does not have a port association with it. Is this because it's running on port 80 or because your doing some fancy proxying? If it's the latter, how can I do that with my server?
-JesterEE
JesterEE
Postby sindre_mehus » Fri Nov 12, 2010 9:14 am
It's simply running on port 80 :-)
Cheers,
Postby GJ51 » Sat Nov 13, 2010 7:26 am
Anybody know the proper settings to get into the demo server from android?
guest
guest
This is what I tried, but I get, wrong username or password.
I put a different server in that spot and now I can't restore it. I suppose I could do a reinstall, but that seems a bit extreme.
Thanks for any help.
Postby sindre_mehus » Sat Nov 13, 2010 7:28 am
user: android-guest, password: guest
Postby GJ51 » Sat Nov 13, 2010 7:37 am
Thanks Sindre.
Return to Announcements
