Subsonic 6.0.beta2 released
Re: Subsonic 6.0.beta2 released
Postby acroyear » Mon May 02, 2016 5:07 pm
maybe there's something funny about the ID3 tag used by .flac files for disc #, different from the tag used by mp3s?
My collection is mp3 and multi-disc albums are sorted fine.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby cnliberal » Tue May 03, 2016 1:09 pm
acroyear wrote:maybe there's something funny about the ID3 tag used by .flac files for disc #, different from the tag used by mp3s?
Joe,
Are your disc tags in the same format mine are?
Disc: 01/01
Disc: 01/02
Disc: 02/02
If there's another way to read the tag directly, that could maybe shed some light on the issue. I'm using MP3Tag and MediaMonkey to sort my music. Thanks!
cnliberal
Postby acroyear » Tue May 03, 2016 2:31 pm
I use iTunes to fix my disc issues usually. The tag is TPOS, and I usually get something like
May 3, 2016 10:26:27 AM org.jaudiotagger.tag.id3.framebody.AbstractID3v2FrameBody read
INFO: Reading body forTPOS:6
May 3, 2016 10:26:27 AM org.jaudiotagger.tag.datatype.NumberFixedLength readByteArray
INFO: Read NumberFixedlength:0
May 3, 2016 10:26:27 AM org.jaudiotagger.tag.datatype.PartOfSet readByteArray
INFO: Read SizeTerminatedString:6/10 size:5
TPOS ==> "Part of Set"
I believe JAudioTagger, or a derivative, is also the library used in Subsonic. Note, I don't have any that have a leading 0, in either the disc number nor the total discs. In the API, the JSON gives me a number back. It could be that those leading 0s you have are causing the tag parser to fail? I can't say if they are in the file itself or just in the rendering.
Joe Shelby
acroyear
Postby centuryx476 » Fri May 06, 2016 1:11 pm
Where is the subtitle option?
I have many shows with subtitle options and would like to turn subtitles on.
Thank You
centuryx476
Previous
Return to Announcements
