play:Sub 2022.1 (iOS): Sleep timer, bugfixes
Postby Michael Bech Hansen » Wed May 25, 2022 6:34 pm
Hi all,
I thought it was time someone used this announcement board for something :wink:, so here goes:
There is a new version of play:Sub headed to the iOS App Store right now...
Here's the the full list of news:
SLEEPTIMER, BUGFIXES
● New: In-app sleep timer available from the player screen,
● New: URL Scheme support for controlling sleep timer:
playsubapp://set?sleeptimer=15
playsubapp://set?sleeptimer=endoftrack
playsubapp://set?sleeptimer=off
● New: App now requires iOS 14+
● New: Updated Navidrome support to enable lyrics and server scan status.
● Fixed: Safari reader mode now follows dark/light theme of app.
● Fixed: Settings screens now follows dark/light theme of app.
● Fixed: NavigationBar message was truncated on some devices.
● Fixed: Crash on iPads when clearing audio or image cache.
● Fixed: On iOS 15, on iPad, the player screen could not be dismissed using the chevron-button (new multitasking took precedence)
● Fixed: Searchfield was hidden when using search as a tab on certain phone models.
● Various other bugfixes and improvements
Rock on!
Michael
Developer of play:Sub for iOS.
https://geo.itunes.apple.com/us/app/play-sub-subsonic-music-streamer/id955329386?mt=8
Michael Bech Hansen
Re: play:Sub 2022.1 (iOS): Sleep timer, bugfixes
Postby chasmo » Fri May 27, 2022 8:28 pm
Thanks for the updates, Michael.
Did you make changes to the way shortcut URL's work? As of this version, my old shortcuts to playlists and radio stations still launch the player, but they no longer select or play the item.
I'm on iOS 15.5, iPhone Xs
chasmo
Postby Michael Bech Hansen » Fri May 27, 2022 9:20 pm
chasmo wrote:Did you make changes to the way shortcut URL's work? As of this version, my old shortcuts to playlists and radio stations still launch the player, but they no longer select or play the item.
Yeah, I managed to break the shortcut URLs completely with this version :(
There is a fixed version with Apple, so within a day or two there should be a new version available.
Sorry for the inconvenience!
/Michael.
Michael Bech Hansen
Postby sgtevmckay » Sat May 28, 2022 11:47 pm
Many thanks :D
sgtevmckay
Postby Michael Bech Hansen » Tue May 31, 2022 7:07 pm
And... the fixed version is out.
Cheers,
Michael
Michael Bech Hansen
Postby chasmo » Tue May 31, 2022 9:14 pm
Hi Michael; it looks like Chromecast support isn't working for the last couple of releases. I can see devices listed, but they are greyed out and won't select. I was using that feature daily prior to the upgrade.
I've also verified that I can stream normally to any of those same devices from other audio apps.
Chasmo
chasmo
Postby Michael Bech Hansen » Thu Jun 02, 2022 6:57 pm
I'll get around to updating the Chromecast SDK soon - hopefully it's a minor thing.
Cheers,
Michael
Michael Bech Hansen
Return to Announcements
Users browsing this forum: No registered users and 38 guests
