Subsonic 4.0.beta2 released
Postby sindre_mehus » Thu May 06, 2010 11:04 am
Dear Subsonic users,
I just put out Subsonic 4.0.beta2: http://subsonic.org/pages/changelog.jsp
Lots of new themes and some important bug fixes.
Please report any issues in this thread.
Cheers,
Beta2
Postby daniell » Sat May 08, 2010 7:12 am
Seems like the new JW Player hang from time to time. Have to choose and Click on another song and then return to get it start playing/streaming.
There is also some new themes which don't respond if you choose/select from the letter on the top left side..
Running Ubuntu 10.4 subsonic.war and tomcat6
daniell
Postby serond » Sat May 08, 2010 8:09 am
Anyone else got problem with the chat?
the first chat line i put in works ok. but if I enter more than 1 everything dissapear.
Maybe som leftover somewhere from beta 1?
serond
Postby utopian » Sat May 08, 2010 10:47 am
can't seem to play anything from the web player...:( all albums showing fine but nothing plays.. WHS with all tracks m4a...
utopian
Postby sindre_mehus » Sat May 08, 2010 11:30 am
serond wrote:Anyone else got problem with the chat?
If possible, could you create a temporary account for me on your Subsonic server so I can have a look?
TIA,
Postby wakajazz » Sat May 08, 2010 2:02 pm
Sindre,
Many thanks for fixing proper ordering of songs on multi-disc albums.
Good work.
wakajazz
m4a playback broken ? (transcoding)
Postby jeankalud » Sat May 08, 2010 3:08 pm
Hello, I used to listen to m4a files and it was working with 3.9.
The song simply never start.
Any mp3 file play fine.
Windows 7 64b, using the web player
I wish to help you with that issue.
Here's the log of concerned items:
[5/8/10 11:01:45 AM EDT]   INFO   PlaylistInputStream   admin listening to "iTunes Session\01 Prisoners of Today (iTunes Sessio.m4a"
[5/8/10 11:01:45 AM EDT]   DEBUG   TranscodeInputStream   Starting transcoder: [c:\subsonic\transcode\faad] [-w] [C:\Users\UserName\Music\iTunes\iTunes Media\Music\Billy Talent\iTunes Session\01 Prisoners of Today (iTunes Sessio.m4a]
[5/8/10 11:01:45 AM EDT]   DEBUG   TranscodeInputStream   Starting transcoder: [c:\subsonic\transcode\lame] [-b] [128] [-x] [-] [-]
[5/8/10 11:01:45 AM EDT]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\lame) Assuming raw pcm input file : Forcing byte-swapping
[5/8/10 11:01:45 AM EDT]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\lame) LAME version 3.96.1 (http://lame.sourceforge.net/)
[5/8/10 11:01:45 AM EDT]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\lame) CPU features: MMX (ASM used), SSE, SSE2
[5/8/10 11:01:45 AM EDT]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\lame) Using polyphase lowpass filter, transition band: 17249 Hz - 17782 Hz
[5/8/10 11:01:45 AM EDT]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\lame) Encoding to
[5/8/10 11:01:45 AM EDT]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\lame) Encoding as 44.1 kHz 128 kbps j-stereo MPEG-1 Layer III (11x) qval=3
[5/8/10 11:01:46 AM EDT]   DEBUG   AudioScrobblerService   Successfully registered now playing for song 'Prisoners of Today (iTunes Session)' for user username at Last.fm.
I can set you an account if needed.
jeankalud
Postby jeankalud » Sat May 08, 2010 3:18 pm
Update.
I does play in the iSub iPhone application. So the transcoding works. The problem is around the web player, playing m4a files through transcoding, or such.
Hope it helps
jeankalud
Postby einsteinx2 » Sat May 08, 2010 4:11 pm
jeankalud wrote:Update.
Hope it helps
I can confirm this. Just tested a couple m4a's and couldn't get them to play in the web player with transcoding on (browsing on my mac in firefox) but they played fine in iSub. Was able to play a FLAC file fine through the web player though. Turned off transcoding for m4a files and the web player worked.
Btw, the new aac tag reading is working great :)
einsteinx2
Postby baxtr » Sat May 08, 2010 5:35 pm
Installed beta 2 over 3.9, all worked great yesterday, listened to music all day remotely from work. played a little this AM then it froze, I logged out, tried to get back to the url and I get the
"HTTP ERROR: 404
NOT_FOUND
RequestURI=/index.view
Powered by jetty://"
Tried reinstall/ firewall/AV off everything cant' seem to get it back again :( I am trying to figure it out without deleting my users, but if I have to......I will
EDIT: Ok, not sure how, because as I said, I listened to it all day yesterday and some this morning, but my router port was forwarded fine, but the checkbox for UPNP in Subsonic was unchecked, checking it fixed the issue. Don't now how it got changed, I am the only Admin in my subsonic. Thanks as always for a great great application
baxtr
Postby sindre_mehus » Sun May 09, 2010 6:42 pm
jeankalud wrote:I does play in the iSub iPhone application. So the transcoding works. The problem is around the web player, playing m4a files through transcoding, or such.
Thanks a lot for providing a test account for me, it allowed me to quickly find out what the problem was. It's a bit complicated to explain, but easy to fix.
The "old" (3.9 and earlier) way of transcoding m4a was to use faad+lame (as configured in Settings > Transcoding). However, in 4.0, I replaced the faad converter with the more general ffmpeg. So your configuration refers to a converter (faad) that is not in your c:/subsonic/transcode directory, which is why it fails. (Did you manually delete anything in c:/subsonic when upgrading? I thought that the old transcoders would not be deleted when upgrading with the Windows installer).
Anyway, to solve it you can choose one of the following solutions:
1. Wait for the final 4.0 release. I'll add the faad converter again to avoid this problem.
2. Change your transcoder settings to use ffmpeg. See http://subsonic.org/pages/transcoding.jsp
3. Disable the m4a>mp3 transcoding altogether, as Subsonic now supports native streaming of m4a (or aac, to be specific).
Thanks again for helping me getting to the bottom of this.
Postby jeankalud » Sun May 09, 2010 7:48 pm
Hello Sindre!
sindre_mehus wrote:(Did you manually delete anything in c:/subsonic when upgrading? I thought that the old transcoders would not be deleted when upgrading with the Windows installer).Sindre
No I didn't. I installed the 3.9 last week and did an install of 4.0 beta 2 over it (never installed beta 1). I hope it helps to focus on the exact source of the settings not being correctly updated.
sindre_mehus wrote:Thanks again for helping me getting to the bottom of this.
You're welcome, thanks to you for this great software!
jeankalud
Postby tacgnol » Mon May 10, 2010 11:52 am
I really like the new themes (Pink Panther, Simplify, Denim) but the ABC links to anchors on the left panel don't work when they are enabled.
tacgnol
Postby derlachendehans » Mon May 10, 2010 1:28 pm
Hi Sindre,
since 4.0 beta1 i´ve a problem running subsonic.war on tomcat6.
after some 30 minutes runnning some threads get stuck.
after starting a rescan of the search index same problem.
then i´m not able to stop the application in tomcat manager or stop tomcat itself.
i´ve to kill the tomcat processes with kill -9 ... so i don´t have any log entries :(
os is arch linux 64bit, tomcat is 6.0.26. problem can also be reproduced on windows 7 running tomcat.
btw great application, really like it
Regards
Joerg
derlachendehans
Postby sindre_mehus » Mon May 10, 2010 4:11 pm
When this happens, can you please do "kill -3 <tomcat pid>" and capture the thread dumps that are written to the tomcat log?
Return to Announcements
