Subsonic 4.3 released
Postby sindre_mehus » Fri Jan 07, 2011 10:52 pm
Just released 4.3 with some video-related bugfixes.
Have a great day!
"Video not found or access denied" if bw set >1
Postby ihf » Sat Jan 08, 2011 7:33 pm
This release has apparently fixed the "multiple of 2 problem" however I now have another problem which I'm not sure is new to this release. WhenI play a video with the speed set at 500Kbps it is somewhat pixelated so I increase the streaming speed to 1000kbps...still blotchy. So I increase to 1200kbps (or 1500 or 2000) and now I get the same message I got before this release..."Video not found or access denied".
ihf
Postby sindre_mehus » Sat Jan 08, 2011 8:29 pm
Is there an error message from ffmpeg in the Subsonic log?
Postby ihf » Sun Jan 09, 2011 4:35 pm
[2011-01-09 11:33:08,608] INFO PlaylistInputStream - admin listening to "nfs/test.m4v"
[2011-01-09 11:33:08,614] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/home/music/nfs/test.m4v] [-async] [1] [-b] [1500k] [-s] [853x464] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-]
[2011-01-09 11:33:08,644] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) FFmpeg version 0.5.2, Copyright (c) 2000-2009 Fabrice Bellard, et al.
[2011-01-09 11:33:08,644] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) configuration: --prefix=/usr --libdir=/usr/lib --shlibdir=/usr/lib --mandir=/usr/share/man --incdir=/usr/include --disable-avisynth --extra-cflags=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m32 -march=i386 -mtune=generic -fasynchronous-unwind-tables --enable-avfilter --enable-avfilter-lavf --enable-libdirac --enable-libfaac --enable-libfaad --enable-libfaadbin --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libx264 --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-shared --enable-swscale --enable-vdpau --enable-version3 --enable-x11grab
[2011-01-09 11:33:08,644] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavutil 49.15. 0 / 49.15. 0
[2011-01-09 11:33:08,644] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavcodec 52.20. 1 / 52.20. 1
[2011-01-09 11:33:08,644] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavformat 52.31. 0 / 52.31. 0
[2011-01-09 11:33:08,645] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavdevice 52. 1. 0 / 52. 1. 0
[2011-01-09 11:33:08,645] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavfilter 0. 4. 0 / 0. 4. 0
[2011-01-09 11:33:08,645] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libswscale 0. 7. 1 / 0. 7. 1
[2011-01-09 11:33:08,645] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[2011-01-09 11:33:08,645] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) built on Jun 13 2010 23:49:29, gcc: 4.1.2 20080704 (Red Hat 4.1.2-48)
[2011-01-09 11:33:08,754] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)
[2011-01-09 11:33:08,754] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (180000/1) -> 90000.00 (180000/2)
[2011-01-09 11:33:08,754] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/home/music/nfs/test.m4v':
[2011-01-09 11:33:08,754] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Duration: 01:33:15.15, start: 0.-100200, bitrate: 1111 kb/s
[2011-01-09 11:33:08,754] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.0(und): Video: h264, yuv420p, 720x464, PAR 32:27 DAR 160:87, 90k tbr, 90k tbn, 180k tbc
[2011-01-09 11:33:08,755] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16
[2011-01-09 11:33:08,755] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.2(und): Subtitle: text / 0x74786574
[2011-01-09 11:33:08,755] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Frame size must be a multiple of 2
ihf
Postby sindre_mehus » Sun Jan 09, 2011 4:38 pm
Hm, I thought I fixed that in 4.3. Can you please double-check that you're running version 4.3 and not 4.3.beta1?
Thank you,
Sindre[/b]
Postby ihf » Sun Jan 09, 2011 4:45 pm
Version 4.3 (build 2078) – January 7, 2011
ihf
Postby stozher » Sun Jan 09, 2011 5:12 pm
"Stream #0.0(und): Video: h264, yuv420p, 720x464 ..."
"[-s] [853x464]"
"Frame size must be a multiple of 2"
stozher
Postby sindre_mehus » Sun Jan 09, 2011 5:40 pm
Thank you. I've found and fixed the problem (which was caused by the combination of the original width and pixel aspect rate being an odd number; a case that wasn't supported).
As a work-around you can upgrade your ffmpeg to 0.6 or later.
Thanks again for reporting it!
Postby ihf » Sun Jan 09, 2011 6:27 pm
I upgraded to the SVN version of ffmpeg and the problem is gone. However, I notice that the play progress bar now has NaN:NaN on the right (where the length would be). Is this a problem with the ffmpeg version or something else? Probably unrelated, but when I did the make I had to use --disable-yasm to get the configure to work.
ihf
Postby sindre_mehus » Sun Jan 09, 2011 8:57 pm
ihf wrote:I upgraded to the SVN version of ffmpeg and the problem is gone. However, I notice that the play progress bar now has NaN:NaN on the right (where the length would be). Is this a problem with the ffmpeg version or something else? Probably unrelated, but when I did the make I had to use --disable-yasm to get the configure to work.
Is the drop-down box with all the time offsets populated (beneath the video screen)? Could you post the log of the ffmpeg command?
Postby ihf » Sun Jan 09, 2011 9:16 pm
Yes, the Time pulldown is populated.
Here is part of the log. Please let me know if you need more.
[2011-01-09 16:10:07,298] INFO PlaylistInputStream - admin listening to "nfs/test.m4v"
[2011-01-09 16:10:07,307] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/home/music/nfs/test.m4v] [-async] [1] [-b] [1500k] [-s] [853x464] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-]
[2011-01-09 16:10:07,328] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) FFmpeg version SVN-r26287, Copyright (c) 2000-2011 the FFmpeg developers
[2011-01-09 16:10:07,329] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) built on Jan 9 2011 12:53:42 with gcc 4.1.2 20080704 (Red Hat 4.1.2-48)
[2011-01-09 16:10:07,329] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) configuration: --disable-yasm
[2011-01-09 16:10:07,329] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavutil 50.36. 0 / 50.36. 0
[2011-01-09 16:10:07,329] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavcore 0.16. 0 / 0.16. 0
[2011-01-09 16:10:07,329] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavcodec 52.108. 0 / 52.108. 0
[2011-01-09 16:10:07,329] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavformat 52.92. 0 / 52.92. 0
[2011-01-09 16:10:07,329] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavdevice 52. 2. 3 / 52. 2. 3
[2011-01-09 16:10:07,329] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavfilter 1.72. 0 / 1.72. 0
[2011-01-09 16:10:07,329] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libswscale 0.12. 0 / 0.12. 0
[2011-01-09 16:10:07,543] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mov,mp4,m4a,3gp,3g2,mj2 @ 0x910e4c0] max_analyze_duration reached
[2011-01-09 16:10:07,544] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)
[2011-01-09 16:10:07,544] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 23.98 (48000/2002)
[2011-01-09 16:10:07,544] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/home/music/nfs/test.m4v':
ihf
Postby sindre_mehus » Mon Jan 10, 2011 12:06 pm
Isn't there more output from ffmpeg? In particular a line telling the duration etc about the input file?
Postby ihf » Mon Jan 10, 2011 12:42 pm
[2011-01-10 07:37:44,053] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) FFmpeg version SVN-r26287, Copyright (c) 2000-2011 the FFmpeg developers
[2011-01-10 07:37:44,053] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) built on Jan 9 2011 12:53:42 with gcc 4.1.2 20080704 (Red Hat 4.1.2-48)
[2011-01-10 07:37:44,053] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) configuration: --disable-yasm
[2011-01-10 07:37:44,053] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavutil 50.36. 0 / 50.36. 0
[2011-01-10 07:37:44,053] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavcore 0.16. 0 / 0.16. 0
[2011-01-10 07:37:44,053] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavcodec 52.108. 0 / 52.108. 0
[2011-01-10 07:37:44,053] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavformat 52.92. 0 / 52.92. 0
[2011-01-10 07:37:44,053] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavdevice 52. 2. 3 / 52. 2. 3
[2011-01-10 07:37:44,053] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavfilter 1.72. 0 / 1.72. 0
[2011-01-10 07:37:44,053] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libswscale 0.12. 0 / 0.12. 0
[2011-01-10 07:37:44,137] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mov,mp4,m4a,3gp,3g2,mj2 @ 0x90714c0] max_analyze_duration reached
[2011-01-10 07:37:44,137] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 23.98 (48000/2002)
[2011-01-10 07:37:44,137] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/home/music/nfs/test.m4v':
[2011-01-10 07:37:44,137] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Metadata:
[2011-01-10 07:37:44,137] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) major_brand : mp42
[2011-01-10 07:37:44,137] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) minor_version : 0
[2011-01-10 07:37:44,137] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) compatible_brands: mp42isomavc1
[2011-01-10 07:37:44,138] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) creation_time : 2010-07-17 22:17:20
[2011-01-10 07:37:44,138] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) encoder : HandBrake 0.9.4 2009112300
[2011-01-10 07:37:44,138] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Duration: 01:33:15.05, start: 0.000000, bitrate: 1111 kb/s
[2011-01-10 07:37:44,138] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Chapter #0.0: start -0.100200, end 272.272000
ihf
Postby sindre_mehus » Mon Jan 10, 2011 12:51 pm
Thanks, that looks fine. Can you now please start the video in the browser, and view the html source. Look for two lines looking like this:
var timeOffset = 0;
and
duration:6542 - timeOffset,
Postby ihf » Mon Jan 10, 2011 12:59 pm
This is running on a Droid 2. How can I access the HTML source?
ihf
Return to Announcements
