iSub bugs
iSub bugs
Postby wilfr » Sun Jan 23, 2011 7:06 pm
iSub has a few bugs around handling of username/passwords -- almost to the point where it has become unusable for me. Let me give everyone a hint - don't change the user's password. After i did that (for both admin and the one I use for iSub), it would report that the API had expired (I have a licensed version of SubSonic) and refuse to reload album lists, etc. My subsonic.log was rife with authentication failures so I finally loaded up wireshark and could plainly see that iSub was sending old passwords -- even though I had reset it several times, removed and added back the server entry, killed the app, and hell, even rebooted my iPhone. One hallelujah moment I had was that it started sending the new password when I marked the ONLY server my DEFAULT server, but I still get authentication errors loading my albums list. Obviously there is some cached values in iSub that I can't purge and it's pretty frustrating.
wilfr
Postby frason » Fri Feb 04, 2011 7:50 am
Remove/reinstall?
frason
Postby einsteinx2 » Sun Feb 06, 2011 10:26 pm
I'm sorry to hear about these issues. If you are currently experiencing the problems you described, a reinstall of the app should clear it up.
There are some bugs regarding the user account handling in version 2.2.3. I have completely re-written all that code in the new 3.0 update that is currently in the review process and should be available within days. So these issues should no longer be a problem. If for some reason they continue to happen after you try version 3.0, please send me an email at support@isubapp.com and I'll make sure to fix it for 3.0.1.
iSub Developer - isubapp.com - support@isubapp.com
einsteinx2
Return to Announcements
