Thumper -- A native OS X client for Subsonic
Postby Thumper » Sun May 01, 2011 4:33 pm
Thumper 1.4.3
I would like to announce the release of my OS X 10.6 client for Subsonic. It supports local caching, keyboard shortcuts, and media key integration.
Thumper requires OS X 10.6 64-bit.
View the full list of features and FAQ here: http://www.thumperapp.com
Features:
- A Native Mac Application - designed on the Mac, for the Mac
- Local Caching of Library Information, Audio, and Album Art - reduce bandwidth and get a more responsive experience
- Browse Artists, Albums, and Songs
- Quick Artist Filter - quickly narrow your results
- Playlists - play, create, and delete Subsonic playlists
- Search - find the song you're looking for quickly
- Current Playlist Persistence - pickup right where you left off, even after a reboot
- Mac Media Key Integration - previous, play/pause, and next key support
- Keyboard Shortcuts - control volume, repeat, shuffle, etc. through keyboard shortcuts
- Last.fm Integration - songs are scrobbled as they're played
- Playback via QuickTime - if QuickTime can play it, so can Thumper
- View Random, Newest, Highest Rated, Most Frequent, and Recently Played Albums
- Smart Playlist Creation - get random songs narrowed by genre or year
- Now Playing Support - See what other users are listening to
- Transcoding (including FLAC) support with Subsonic 4.6 or greater
- Video streaming (requires proper codec to be installed, see FAQ)
Requires Mac OS X 10.6 or greater. Does not support Subsonic's downsampling (reducing the audio bitrate).
Please read the Thumper FAQ about FLAC support http://www.thumperapp.com/help
Thumper 1.4.0 - January 10, 2012
- Feature: Video streaming support
- Feature: Create share links for albums and songs
- Feature: Rate songs and albums
- Feature: Control max bit rate transcoding client side
- Feature: Added menu for dock icon, controls and playing song information
- Feature: Ability to select specific media folders
- Bug fix: Support transcoding of audio
- Bug fix: Streaming of FLAC files now supported (requires FLAC > MP3 transcoding)
- Bug fix: Fixed lack of Copy/Past support
- Bug fix: Disable preemptive downloading of FLAC audio
- Bug fix: Mac App Store Sandboxing/Code Signing
- Bug fix: Replaced Growl notifications with a menu bar notification system
- Bug fix: Disabled Apple Remote Control due to App Store Sandboxing requirements
- Bug fix: Preemptive downloading only works if permission exists for the user
Thumper 1.3.1 - September 14, 2011
- Feature: Next, Previous, and Play/Pause support for Apple Remote Control
- Bug fix: Problem with using *.subsonic.org urls
- Bug fix: Problem downloading some album art
Thumper 1.3.0 - August 16, 2011
- Bug fix: Quick Playlist Focus
- Bug fix: Better behavior when application is reopened
- Bug fix: Reset progress bar when clearing playlist
- Bug fix: When adding all songs from album to playlist, this should be done in another thread
- Bug fix: Highlight the first album when it is they only album
- Bug fix: Previous button should play same song if play time is more than 3 seconds
If you find any bugs, or run into any problems, please feel free to contact me at support@thumperapp.com.
Thanks for looking!
Thumper
Postby dcuellar » Tue May 03, 2011 10:56 pm
Looks and works very nice. Any way of incorporating something like CoverSutra and YouControl which allow you to play and search for songs from the status bar of OS X?
That would make this all the more worthwhile.
dcuellar
Postby Thumper » Wed May 04, 2011 10:30 pm
dcuellar wrote:Looks and works very nice. Any way of incorporating something like CoverSutra and YouControl which allow you to play and search for songs from the status bar of OS X?
Thanks for the compliments dcuellar! It is good to hear that it works for you and that you like it!
I'll look into adding a menu bar for controls and search, but it wouldn't be added until a later release. Thanks for the suggestion!
Thumper
Postby ebasta » Thu May 05, 2011 8:06 pm
Hello. "You can’t open the application “Thumper.app” because it’s not supported on this type of Mac.". I am running osx 10.6.7.
ebasta
Postby Thumper » Thu May 05, 2011 8:19 pm
ebasta wrote:Hello. "You can’t open the application “Thumper.app” because it’s not supported on this type of Mac.". I am running osx 10.6.7.
Hi Ebasta,
What type of hardware are you running this on? If you would like to contact me via email (support@thumperapp.com), I am sure we would be able to get you dialed in.
Thumper
Postby swentz » Fri May 06, 2011 10:07 am
Thumper runs fine here, but all I get is a listing of the artists inside of my subsonic instance.
When I click on an artist the albums column shows a loading indicator, but nothing is happening.
The subsonic log doesn't show anything about this problem.
Are there any thumper-logs that might show the problem?
swentz
Postby Thumper » Fri May 06, 2011 2:45 pm
swentz wrote:Hi,
Hi Swentz,
What version of the Subsonic server are you running? If you launch the Console application while running Thumper, it should put out any errors that it might run into. Feel free to jet me an email at Support@thumperapp.com.
Thumper
Postby dcuellar » Fri May 06, 2011 10:08 pm
Thanks thumper. It would be great if I could edit the tags and have more admin options.
The only thing that bothers me is I find myself going back to my admin account on the browser. Since it's bookmarked it's pretty much the same as opening this application. What is going to make Thumper a better user experience for the user than say just opening up the browser? That's what I think these applications need to be focusing on.
If I can provide some feedback I would suggest having a method for better playlist creation. If possible, add ratings per song instead of just albums and store them locally. Keep count of number of times played also. These are things that can help in creating a better playlist creation method and are currently not available through subsonic.
dcuellar
Postby Thumper » Fri May 06, 2011 10:58 pm
dcuellar wrote:Thanks thumper. It would be great if I could edit the tags and have more admin options.
Hi dcuellar,
The web interface for Subsonic is great and will provide the most functionality. Since not all of the features of the web interface (such as ratings, and play count) aren't implemented via the Subsonic API, it would provide an inconsistant experience across clients to implement just in Thumper (even in separate Thumper instances).
Here are some features that Thumper has that the web interface does not:
- Keyboard shortcuts
- Mac Media key support
- Local caching
- QuickTime codec support
I would definitely like to hear more suggestions on what users would like to see integrated into the app!
Thumper
Postby calvintml » Sat May 07, 2011 10:44 pm
I am having the same issue as ebasta. I have a core duo macbook pro (not 64 bit). I get this error if I try to run a 64 bit application. Any chance you could compile a 32 bit version too if this is the problem?
calvintml
Postby Thumper » Sun May 08, 2011 12:56 am
calvintml wrote:I am having the same issue as ebasta. I have a core duo macbook pro (not 64 bit). I get this error if I try to run a 64 bit application. Any chance you could compile a 32 bit version too if this is the problem?
Hi Calvintm,
Sorry for not posting this in response to Ebasta. Thumper uses 64bit only libraries, there for it will only run on Snow Leopard in 64bit mode. Since Apple is moving from 32bit to 64bit, I have no plans on adding support for 32bit systems.
Thanks for looking!
Thumper
Postby atka » Sun May 08, 2011 2:01 pm
I have a problem with Thumper not playing some songs. It seems random to on file well play from a CD rip and then another one won't. They all play fine streamed to my phone or through subair though.
atka
Postby Thumper » Sun May 08, 2011 10:30 pm
atka wrote:I have a problem with Thumper not playing some songs. It seems random to on file well play from a CD rip and then another one won't. They all play fine streamed to my phone or through subair though.
Hi atka,
What codec are you using for these "problem" files? Feel free to jet me an email, I would like to get this figured out. Support@thumperapp.com
Thumper
Postby atka » Mon May 09, 2011 12:08 am
OK so far it looks like I fixed it somehow. The only thing I have done is moved my SSL port, restarted subsonic service and added the server again into Thumper and now the "problem" songs seem to be working.
I guess a feature request of sorts is it possible to add folders to the app? Some of my shared folders contain video and it would be nice to not see them when listing to music.
atka
Postby Thumper » Tue May 10, 2011 5:17 pm
atka wrote:OK so far it looks like I fixed it somehow. The only thing I have done is moved my SSL port, restarted subsonic service and added the server again into Thumper and now the "problem" songs seem to be working.
This has to do with the LAME downsampling that Subsonic uses. I'm not sure if I'll add support for downsampling in Thumper in the future or not.
Thumper
Return to Announcements
