Thumper -- A native OS X client for Subsonic
Re: Thumper -- A native OS X client for Subsonic
Postby okeeblow » Mon Jun 04, 2012 2:44 pm
Thumper wrote:
okeeblow wrote:I'd love to give this a shot since Submariner is so broken, but it seems to require 10.7 now :(
Yes, with Apple on the verge of releasing OS X 10.8 this year, Thumper will only support OSX 10.7 and up. I hope you can get upgraded and enjoy Thumper soon!
I'll probably hold out on 10.6 as long as it's viable. Lion and newer bring too many unsavoury changes. Where can I find a download of the last 10.6-compatible version of Thumper?
okeeblow
Postby Thumper » Mon Jun 04, 2012 3:43 pm
okeeblow wrote:I'll probably hold out on 10.6 as long as it's viable. Lion and newer bring too many unsavoury changes. Where can I find a download of the last 10.6-compatible version of Thumper?
I'm sorry, but there isn't one anymore. I suggest you try Subair, or one of the other clients until you upgrade.
Thumper
Postby R1G » Tue Jun 19, 2012 12:44 pm
Thumper is caching songs just fine and I can add all those MP3s to iTunes unless they are Track 1 of an album. Everything opens with iTunes apart from something that is Track 1.
Is there any way around this?
R1G
Postby Thumper » Tue Jun 19, 2012 2:36 pm
R1G wrote:Thumper is caching songs just fine and I can add all those MP3s to iTunes unless they are Track 1 of an album. Everything opens with iTunes apart from something that is Track 1.
Hrm, there might be a problem with how Thumper is actually caching the first track. Can you play it with any other player (maybe VLC?)? Shoot me an email at support@thumperapp.com and we'll get you fixed.
Thumper
Postby replicant » Tue Jul 31, 2012 4:48 am
Howdy Thumper, you still actively developing on this bad boy? I really want to buy either this or Submariner, but both apps look to have died off on development. Before I spend that hard-earned cash-money, can you let us know if you're going to be at least going to make sure mountain lion compatibility is coming? thanks champ.
replicant
Postby Thumper » Fri Aug 03, 2012 7:43 pm
replicant wrote:Howdy Thumper, you still actively developing on this bad boy? I really want to buy either this or Submariner, but both apps look to have died off on development. Before I spend that hard-earned cash-money, can you let us know if you're going to be at least going to make sure mountain lion compatibility is coming? thanks champ.
Yes, Thumper is still under development. I even have a 1.4.2 version almost ready to go. It may be ending it's end of life as product for me though.
The Mac App Store Sandboxing rules are going to force me to either 1) Remove the media key features in Thumper or 2)Start selling Thumper outside of the Mac App Store. I'm in the appeal process right now, but I don't know how long it will take or if it will be a fruitless effort.
Regardless, 1.4.2 will be released eventually with it's bug fixes and features some day.
Thumper 1.4.2
Feature: Media keys now block iTunes without needing to have Quicktime open
Feature: Control Thumper from the menu bar
Bugfix: All songs are now streamed from the server, fixing FLAC playback issues
Bugfix: Graphical bug in the Songs table
Bugfix: Artist names are now included in the album list for quick playlists
Bugfix: Change of bitrate selection in the preference pane survives application restarts
Bugfix: Album row height is now calculated based on content
Bugfix: Rating changes via an alternate click are displayed in the star indicator
Thanks to everyone who has supported Thumper so far.
Thumper
Postby Thumper » Tue Oct 09, 2012 8:20 pm
I'm happy to announce that Thumper 1.4.2 has been released in the App store. Thank you to everyone who waited this out!
Thumper
Postby germain35 » Wed Oct 10, 2012 9:33 am
GREAT job, think you very much, it works perfectly with Moutnain LION !
germain35
Postby manwithaplan » Thu Nov 15, 2012 2:31 pm
If Thumper doesn't work anymore on 10.6.x, why does the App Store show it as compatible with "10.6 or later" in the "Requirements" area on the right hand side of the App description??? Please clarify. Thank you.
manwithaplan
Postby Thumper » Thu Nov 15, 2012 8:13 pm
manwithaplan wrote:If Thumper doesn't work anymore on 10.6.x, why does the App Store show it as compatible with "10.6 or later" in the "Requirements" area on the right hand side of the App description??? Please clarify. Thank you.
I've removed the features that required 10.7 and higher, so it should now work on 10.6 again. I haven't tested Thumper on 10.6 in quite some time however, so there may be bugs and/or issues.
I plan on actively supporting the current OSX version (10.8 right now) and it's predecessor (10.7).
Thumper
Postby manwithaplan » Fri Nov 16, 2012 12:32 am
Okay, thanks. And as for requiring 64bit OS, is that still accurate, as the App Store says it is required. Please clarify. Thanks.
manwithaplan
Postby Thumper » Fri Nov 16, 2012 4:47 pm
manwithaplan wrote:Okay, thanks. And as for requiring 64bit OS, is that still accurate, as the App Store says it is required. Please clarify. Thanks.
Yes, a 64-bit version of OSX is required.
Thumper
Postby KicknGuitar » Mon Dec 03, 2012 9:36 am
I'd love to have an app instead of a webpage controlling my music, specifically for the use of shortcut keys. But if there's one thing holding me back from your app is the layout. To give you an idea, I have my iTunes set up usually like a list:
Since most of my time in front of my music library is sorting through thousands of songs, the simple text of song name artist etc. is all I need, but the minimalist approach I appreciate too. Is this offered in your app?
The beauty of sharing one's work:
Subsonic • MusicCabinet • Madsonic
KicknGuitar
Postby Thumper » Fri Dec 21, 2012 8:00 pm
Thumper faithfuls:
2012 has been a great year. Thank you for all your support and feedback. 2013 will be a year of change, especially for Thumper.
Until then, please do enjoy Thumper at it's lower price in the App Store!
I wish you a happy ending to 2012, and look forward to what 2013 holds.
Daniel
Thumper
Postby Thumper » Wed Jan 02, 2013 6:20 pm
Thumper is now an open source project. It has been licensed under GPLv3, meaning it will remain free from here on out.
I've moved away from Subsonic (iTunes Match for those curious). Thumper was a fun project for scratching my own itch, but that is no longer the case. As a result I'm no longer the correct person to lead the project. This means I will not be contributing to Thumper any longer in support or development form. If you're interested in taking over the project (it is written using MacRuby), please do PM me.
I hope that Subsonic and Thumper continue to grow and develop.
Daniel
Thumper
Return to Announcements
