Retain User Data (Logins/Passwords/Settings/Play Data/Etc)
Postby cntrle » Thu Aug 11, 2011 4:38 pm
I am wondering if it is possible to upgrade from:
4.4 (build 2169) – February 6, 2011
to
Subsonic 4.5
Without losing my user data. I have close to 50 users and it would be a real pain to lose Logins/Passwords/etc.
Let me know if there is any migration path possible.
Thanks for the help!
-cntrle
cntrle
Postby bushman4 » Thu Aug 11, 2011 5:12 pm
What platform?
Actually, that is a moot point. As long as you leave /var/subsonic or c:\subsonic or wherever your subsonic setting directory alone, everything should stay in place.
Back that directory up first if you are worried.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Simulant » Thu Aug 11, 2011 10:51 pm
I've lost my settings everytime I've upgraded... FYI.
Fortunately I have a very simple setup.
(on Windows)
Simulant
Postby GJ51 » Fri Aug 12, 2011 4:38 am
I've never lost anything doing a Subsonic update on Windows, but it's easy enough to just save the C:\Subsonic directory or just rename it, then restore it after you upgrade SS.
Postby glycolized » Sun Aug 14, 2011 3:20 am
I am also on Windows 7 and I have lost my user settings the past two upgrades.
I have backed up that C:/Subsonic folder before, but what file(s) do I want to restore?
I really would just like it if I didn't have to remember what users I had set up and their login info. I was hoping I would find some sort of config file with that data that I could copy over to the upgraded install folder.
glycolized
Postby GJ51 » Sun Aug 14, 2011 3:50 am
Just copy the saved C:\Subsonic directory back to it's original loacation after the upgrade. It is puzzling though, I've never had to do this going back before version 4.0. I just do the standard Windows install and edit the Subsonic service log on permissions so it can access files on network shares and I'm done. It has always retained all my users and settings.
Return to Announcements
