Spotify-based Desktop Application
Postby bmj1086 » Mon Aug 22, 2011 2:51 am
For a good while now I have been writing a subsonic API for C#. Recently I decided to put it to work and I started building a desktop application for Windows. After working with the data access portion of this application for so long I finally found a good UI to build mine around, Spotify. Here are some screenshots of my application. (Note: This is an alpha release; it is nowhere near completed and with my ambition the features will probably be inexhaustible)
Updates will probably come daily so I have limited the application update checks to once daily but you can check for new updates under "Help > About."
I am open to requests but please refrain from suggesting things that are on the TODO list or just plain obvious (such as "repeat" and "random")
Changelog and TODO list will be below.
Download: http://bmjones.com/supersonic
bmj1086
Re: SuperSonic Music Streamer. A Spotify-based UI for Subson
Postby bmj1086 » Mon Aug 22, 2011 2:52 am
Reserved for changelog
bmj1086
Re: Spotify-based Desktop Application
Postby jameskeagie » Wed Aug 24, 2011 3:50 pm
Looking good - the spotify framework should port to other OS'es easily as well!
Someone likes the Architects too huh? See them on tour? I used to hang out w/ Brandon occasionally when I used to live in KC.
jameskeagie
Postby kartoffel » Thu Aug 25, 2011 2:16 am
Hi.
I'm trying to connect to my subsonic server but I get these errors.
The remote server returned an error: (404) Not Found.
Server address: hostname.org
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Net.WebException: The remote server returned an error: (404) Not Found.
   at System.Net.HttpWebRequest.GetResponse()
   at SharpSub.Data.SubsonicRequest.SendRequest(String requestUrl)
   at SharpSub.Data.SubsonicRequest.Login(String serverURL, String username, String password)
   at SuperSonicUI.LoginForm.LoginButtonClick(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
System
    Win32 Version: 4.0.30319.1 built by: RTMRel
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
SuperSonic
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/Carlos/AppData/Local/Apps/2.0/0NO2DA8L.40K/D34EKT6H.0R1/supe..tion_546b23bf1e1b02bc_0000.0009_d289184c212c16e2/SuperSonic.exe
SharpSub.Data
    CodeBase: file:///C:/Users/Carlos/AppData/Local/Apps/2.0/0NO2DA8L.40K/D34EKT6H.0R1/supe..tion_546b23bf1e1b02bc_0000.0009_d289184c212c16e2/SharpSub.Data.DLL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
CustomControls
    Assembly Version: 1.0.4250.31808
    CodeBase: file:///C:/Users/Carlos/AppData/Local/Apps/2.0/0NO2DA8L.40K/D34EKT6H.0R1/supe..tion_546b23bf1e1b02bc_0000.0009_d289184c212c16e2/CustomControls.DLL
System.Xml.Linq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
The remote name could not be resolved: "https".
Server address: https://hostname.org
System.Net.WebException: The operation has timed out
mscorlib
System
SuperSonic
SharpSub.Data
System.Drawing
System.Xml
CustomControls
System.Xml.Linq
enabled.
For example:
<configuration>
</configuration>
My server runs under 443 (SSL) port. Is there any fix for this bug?
Thanks and sorry for my bad english :(
kartoffel
Postby bmj1086 » Thu Aug 25, 2011 9:42 pm
I haven't implemented https support yet. I will implement that soon. I'll have a big update this evening.
bmj1086
Postby Undeadllama » Tue Nov 29, 2011 5:22 pm
Is this still being developed?
Im desperately trying to find a good alternative to the web base client.
In particular I want to be able to use the media control keys on my keyboard to play/pause + skip tracks on subsonic which you obviously can't do with the web interface.
So any news or is this dead now?
Undeadllama
Return to Announcements
