houdini2930/boing,
I had finally gotten my Subsonic working well enough after my other issues I posted about earlier and recently tried to update to version 5.0 per houdini2930's indication that it works fine following the manual install instructions from boing. I followed these and downloaded the appropriate package and moved (overwrote) the two subsonic files. Unfortunately, my Subsonic service will not start now and I fear that I will have to reconfigure everything again. When I attempted to run the service from the Package Center after slipping in v.5 files, I got the message that it could not start the package. I validated the permissions and they were correct. I uninstalled the package from the package center and now I think I am just stuck with having to reconfigure the whole installation from scratch again.
Does anyone have a more foolproof method to install v.5.0 from a fresh installation? Also, how do I clear out everything and start over? Should I dump Serviio, Java and everything and start completely fresh? Does Subsonic work with Java v. 8 (which I currently have installed). Using PuTTY has been a pain in the ass for me as I suck with Unix and Cyberduck was much easier for me to navigate and move files about (including updating permissions) but I can't even get that to work to access the /usr folders or other root-level folders even after enabling SFTP in File Services.
Basically feeling defeated by this process because it worked beautifully for a short time and now it is a train wreck thanks to me. Any help on this is appreciated.
~Dubhead
