Memory allocation on Synology NAS
Postby blindman » Sat Mar 03, 2012 12:23 am
Hi all,
I loaded this "great" application on a DS2411+ w/ 1G of RAM. Each time the application runs it eventually freezes up in the first few hours to a day and a half. When this happens the CPU memory meter states java is consistantly at 25% instead of the typical 3-8%. Also, each time it seems the SearchService reaches a point of 126000 entries.
Could it be the app/java needs more memory? Any idea how to increase it?
BTW, the SEARCH feature also does not work...maybe it's related.
Thanks in advance for any help,
Craig
Synology: DS2413+
blindman
Re: Memory allocation on Synology NAS
Postby blindman » Tue Mar 06, 2012 1:52 pm
Update:
Increased memory allocation to 256 and all is good.
What a great app!
Craig 8)
Synology: DS2413+
blindman
Postby Carl314 » Wed Mar 07, 2012 1:05 am
Craig, I seem to be having the same issue on my 712+, but am a Synology newbie. Can you let me know how you allocated the memory, and to which app (Java or Subsonic)?
Thanks, Carl.
Carl314
Postby blindman » Fri Mar 09, 2012 5:28 am
Hi Carl,
You can adjust the allocated memory in the subsonic.sh file.
it is located in /volume1/@appstore/Subsonic/subsonic.sh
This is done by SSH into the DS
or since I am not a Linux expert, I use the Config File Editor provided by Merty at http://www.mertymade.com Add this package to you DS box and follow the steps below:
- open Config File editor
- add the following path to the Config File Editor: /volume1/@appstore/Subsonic/subsonic.sh,subsonic.sh
- exit out of Config and log back in then choose subsonic.sh
- change the SUBSONIC_MAX_MEMORY= to what ever you need. (default is 100, I changed it to 256 and it works great)
- save and exit
-restart Subsonic and away you go.
Synology: DS2413+
blindman
Postby Carl314 » Sun Mar 18, 2012 9:55 pm
Blindman - thank you for this detailed step-by-step. Subsonic suddenly started working fine - I suspect it was probably having problems during the initial indexing. But I'll bookmark your post in case the problem returns.
Cheers, Carl.
Carl314
Postby blindman » Tue Mar 20, 2012 1:21 am
Carl,
Glad to hear. I have ...
11,488 artists
7,335 albums
118,225 songs
777.52 GB (~ 12,078 hours)
So I need the additional allocation of memory for my indexing to work.
BTW, does your lyrics feature work. It does not on mine.
Take care,
Craig
Synology: DS2413+
blindman
Postby bushman4 » Tue Mar 20, 2012 12:37 pm
The lyrics feature does not currently work for anyone using the stock subsonic build.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby blindman » Tue Mar 20, 2012 11:49 pm
Thanks Glenn,
BTW, I love the size of your music library! 8)
Synology: DS2413+
blindman
Return to Announcements
