Hypersonic - Subsonic client for iOS
Postby joshbetz » Tue May 15, 2012 11:15 pm
My new iOS app, Hypersonic, is now available in the app store: http://bit.ly/hypersonicmp
I'd love to get some input from the Subsonic community!
joshbetz
Re: Hypersonic - Subsonic client for iOS
Postby dunnno » Mon Jun 25, 2012 11:19 am
Bought some weeks ago. It works way much better than other iOS app but i'm facing probs now that it forces close (dunno the term in iOS world). It loads but suddenly goes back to home screen. This happens quite a lot actually. also, a third of my library doesn't play, i don't know why also. Every single file is encoded the same way. For comparison, the subsonic client on Android works very fine (I means I guess it's not a problem from my library).
I'm using Subsonic 4.7b2, self stored.
dunnno
Postby Dutch_Celt » Mon Jun 25, 2012 12:48 pm
Just installed to give it a look over (no loss at a mere € 0,79 cents).
At first startup, put in the address and user credentials, it hung for a few seconds, then promptly crashed to the springboard.
Second attempt, adding https:// to the url, same result.
Third attempt, over 3G instead of wifi, same result.
Could it be due to the server running on https only?
*setup in this case:
Tomcat behind ISS (whs2011) and http-> https redirect in iss, with cert.
iOS 5.1
edit:
Not even starting now, shows hypersonic start screen, then crashes to springboard.
edit 2:
on a sidenote, I wonder if we will hear more from Josh, since his last visit was may 20th :-)
Dutch_Celt
Postby wvcs » Thu Aug 23, 2012 2:09 pm
@Dutch_Celt,
Can you describe how you are performing you redirect from http on IIS7 to Tomcat SSL?
Thansk Bill
wvcs
Return to Announcements
