Question about Subsonic streaming
Postby sandule » Wed Aug 29, 2012 3:03 am
I am still unclear if Subsonic Streaming is true streaming where I can play files directly off of my home server or does it have to be downloaded to the device first?
thanks.
sandule
Re: Question about Subsonic streaming
Postby bushman4 » Wed Aug 29, 2012 11:38 am
Both. In the case of the web interface, a file is downloaded and played while it is being downloaded, but it is not saved or cached anywhere.
On most other platforms the files are pre-cached into a local directory, but they can still be played while they are being cached (as long as enough has been streamed already).
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby sandule » Wed Aug 29, 2012 11:49 am
So there is no way to play the files directly from my home NAS without some sort of downloading to my android device.
With over 4TB of media, the caching is not ideal considering my tablet has only 16gb of storage.
Any other alternatives/work around?
sandule
Postby bushman4 » Wed Aug 29, 2012 11:54 am
Just turn the pre-caching of songs off and set the cache size to something ridiculously small. it will only cache the one song you are playing...
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby sandule » Wed Aug 29, 2012 12:05 pm
Thanks Glenn,
What about movies?
sandule
Postby bushman4 » Wed Aug 29, 2012 12:13 pm
Movies are not cached, except maybe while playing them. I am unsure how JWPlayer (which is the underlying player in all web versions of Subsonic, which is what the Android Platform uses for a video player) handles the file currently being played.
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby dik23 » Fri Aug 31, 2012 8:05 pm
Hot to trot!
SS4.6 running on Lucid32
dik23
