subsonic on windows 7 with java 7
Postby spacebug » Sun Sep 09, 2012 1:41 pm
I recently updated to java 7 on my Windows 7 64-bit OS and sobsonic will not start anymore.
I have tried installing the latest beta since I was on the 4.6 stable before but same issue.
If I try to start the sobsonic service from administrative tools I get "Error 1067: The process terminated unexpectedly"
Installed version of Java is "Java 7 Update 7" version "7.0.70"
Also installed if JavaFX version 2.1.1
spacebug
Re: subsonic on windows 7 with java 7
Postby bsitko » Tue Sep 11, 2012 1:52 pm
I have the same problem. Windows 7 64bit. Newest version of Java. Subsonic fails with the same error. HELP! I'm LOST without my subsonic.
bsitko
Postby bsitko » Tue Sep 11, 2012 2:16 pm
It is definitely the newest version of Java: Java 7 update 7. It will break subsonic. What's a shame here is in order to use subsonic, you'll have to run a version of Java with enough security holes in it to make a block of swiss cheese jealous. Still, everything is up and running now with update 6.
bsitko
Postby spacebug » Wed Sep 12, 2012 4:41 pm
Good to know that it is Java at least.
I think I'll just wait for a fix.
spacebug
Postby GJ51 » Wed Sep 12, 2012 5:34 pm
I run the latest version of Java on all of my Subsonic sites without any problems. They all run on Windows platforms, either Win 2008R2 or Win 2003 code base. The 4.7 final has just been posted for download.
http://sourceforge.net/projects/subsoni ... /subsonic/
You should be able to get good results if you do a clean install of the latest Java and Subsonic 4.7.
I also have MadEvil's latest modded release running fine in the same environment.
Postby bsitko » Wed Sep 12, 2012 7:29 pm
I'll give 4.7 a try. All I can tell you is, worked fine with update 6. Java updated to update 7. Subsonic stopped working. Uninstalled java back to update 6. Works fine again.
bsitko
Postby nutt318 » Wed Sep 12, 2012 7:31 pm
I'm running Windows 7 64bit and had an error with the latest version of Java. This simple fix was to and the location to java7 to the environment variables. Now SS works great.
nutt318
Postby spacebug » Thu Sep 13, 2012 8:16 pm
I just installed 4.7 and it still does not work.
mutt318: Where do you mean I should add the java path enviroment variables?
spacebug
Postby GJ51 » Thu Sep 13, 2012 8:29 pm
And this is a clean install of both the latest Java and Subsonic 4.7?
Somehow, methinks not. :roll:
Postby spacebug » Fri Sep 14, 2012 1:34 pm
I uninstalled both Java and subsonic and installed Java SDK 7 and then installed subsonic 4.7.
It works but subsonic installed java 6 even though I had java 7 installed because somehow it needs java 6.
spacebug
Postby nutt318 » Fri Sep 14, 2012 1:47 pm
@Spacebug, Go to the System Properties and on the Advanced Tab there is a button in the bottom right corner that says Enviroment Variables. Then in the lower box that says System Variables look for the Variable that says 'Path' then click on edit. At the end of the Variable Value add the following ';C:\Program Files (x86)\Java\jre7\bin' but with out the single quotes.
Anyways not sure exactly the error I was receiving but tracked it down to SS not knowing where to find the new location of Java7.
Hope that helps
nutt318
Postby spacebug » Fri Sep 14, 2012 2:19 pm
Since I installed java 7 for 64-bit I had to change the path to without (x86) but subsonic still said it cannot find a jre for 32-bit installed.
I guess I just have to have java 7 64-bit and java 6 32-bit installed
spacebug
Postby GJ51 » Fri Sep 14, 2012 6:40 pm
You must install Java 32 bit. 64 bit Java is optional and only needed if you use a 64 bit browser to access Subsonic.
Install Java 32 bit first. Only add 64 bit if you intend to use IE 9 64 bit.
http://www.java.com/en/download/manual.jsp
"We have detected you may be viewing this page in a 32-bit browser. If you use 32-bit and 64-bit browsers interchangeably, you will need to install both 32-bit and 64-bit Java in order to have the Java plug-in for both browsers. » FAQ about 64-bit Java for Windows"
Postby lovs2build » Wed May 01, 2013 7:34 am
I had same problem as well. I install subsonic onto a java 7 update 21 and would not work. Uninstalled java and put 6 on and all is well. It is definitely java 7 that is causing problems.
Win 7 64
lovs2build
