ClientAbortException
Postby wvcs » Sun Sep 23, 2012 9:18 pm
Recently upgraded to 4.7 (build 3105) – September 11, 2012 and I'm seeing the following error in my logs when streaming music to iPhone:
WARN RESTFilter Error in REST API: ClientAbortException
Not sure what this means or should I be concerned.
Thanks Bill
Server Apache Tomcat/6.0.35, java 1.6.0_26, Windows Server 2008 R2 (180.5 MB / 691.9 MB)
wvcs
Re: ClientAbortException
Postby GJ51 » Sun Sep 23, 2012 11:29 pm
No need to be concerned.
Don't worry, be happy. :lol:
Postby saphyrre » Mon Dec 10, 2012 7:38 pm
Same issue here with iSub (on iPhone), i see connection reset errors after upgrading subsonic to 4.7. Every connection reset causes the payback to stop, so this is a big problem. iSub's developer seems to suggest that the issue is with subsonic rather than the app itself (quote: "Subsonic has some extremely low timeout set for connections and repeatedly closes them while iSub is pausing to keep the rate limit"), so i would like some additional input from somebody that actually know what they are talking about (unlike the ridiculous post above - please do not bother to post in this thread if you have nothing to say).
Error: "WARN RESTFilter - Error in REST API: ClientAbortException ClientAbortException: java.net.SocketException: Connection reset"
Version: 4.7 (build 3105) – September 11, 2012
Server: Apache Tomcat/7.0.27, java 1.7.0_03, Linux (248.3 MB / 1.25 GB), PowerEdge 2950 (dual quad code X5355, 16GB ram, 5.5Tb RAID5), Centos 6 x64 2.6.32-279.11.1.el6.x86_64
About $55k audio files in library
saphyrre
Postby GJ51 » Mon Dec 10, 2012 7:55 pm
saphyrre wrote:Same issue here with iSub (on iPhone), i see connection reset errors after upgrading subsonic to 4.7. Every connection reset causes the payback to stop, so this is a big problem. iSub's developer seems to suggest that the issue is with subsonic rather than the app itself (quote: "Subsonic has some extremely low timeout set for connections and repeatedly closes them while iSub is pausing to keep the rate limit"), so i would like some additional input from somebody that actually know what they are talking about (unlike the ridiculous post above - please do not bother to post in this thread if you have nothing to say).
Subsonic still has some bugs when used with Tomcat 7. Drop back to Tomcat 6.
Postby saphyrre » Mon Dec 10, 2012 8:49 pm
GJ51 wrote:Subsonic still has some bugs when used with Tomcat 7. Drop back to Tomcat 6.
Can you provide more (technical) details on this, or point me to the relevant bugs on http://sourceforge.net/p/subsonic/bugs/ ? I'm not a Java expert, but i'm not exactly a novice either. I'm specifically interested in the cause of the error mentioned above, rather than general "incompatibility" issues.
saphyrre
Postby GJ51 » Mon Dec 10, 2012 8:52 pm
http://www.subsonic.org/pages/installation.jsp#war
Some of the more sophisticated modders can give you more specifics. I'm not a Java guru by any means. I do know that most users who've tried Tomcat 7 usually have errors to deal with that do not manifest themselves in T6. I haven't seen anyone pontificate regarding any advantage to using 7 rather than 6 with Subsonic, so for most of us it just makes more sense to use 6 and not have unexpected problems to deal with.
When you stray from the known baseline you enter into a new dimension when trouble shooting because it will be a deviation from what 99% of the rest of the user base has running.
Postby hakko » Mon Dec 10, 2012 9:09 pm
Tomcat 7 uses JSP 2.2 which has stricter validation than previous version. Sindre has used some reserved keywords (like "new") as variable names in the .jsp files which doesn't compile. This has been fixed in modded versions of the Subsonic server, but not in the official.
MusicCabinet developer
hakko
Postby Munger » Mon Jan 14, 2013 4:07 pm
Dropping back to tomcat 6 is not the solution any more than tomcat 7 is the problem. Like the original poster, I am also using tomcat 6 (6.0.36), and am seeing these messages.
Munger
Postby spookybathtub » Mon Mar 03, 2014 10:10 pm
Has this been fixed yet? I just installed Tomcat7 on a new system, and I'm getting these errors when playing songs with iSub.
[2014-03-03 14:00:08,877] WARN RESTFilter - Error in REST API: ClientAbortException
ClientAbortException:  java.net.SocketException: Broken pipe
   at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:388)
   at org.apache.tomcat.util.buf.ByteChunk.flushBuffer(ByteChunk.java:462)
   at org.apache.tomcat.util.buf.ByteChunk.append(ByteChunk.java:366)
   at org.apache.catalina.connector.OutputBuffer.writeBytes(OutputBuffer.java:413)
   at org.apache.catalina.connector.OutputBuffer.write(OutputBuffer.java:401)
   at org.apache.catalina.connector.CoyoteOutputStream.write(CoyoteOutputStream.java:91)
   at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:221)
   at net.sourceforge.subsonic.controller.RESTController.stream(RESTController.java:1172)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:606)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
   at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:641)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
   at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
   at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:108)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
   at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:55)
   at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:225)
   at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
   at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
   at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
   at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
   at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
   at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
   at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
   at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1001)
   at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579)
   at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
   at java.lang.Thread.run(Thread.java:724)
Caused by: java.net.SocketException: Broken pipe
   at java.net.SocketOutputStream.socketWrite0(Native Method)
   at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:113)
   at java.net.SocketOutputStream.write(SocketOutputStream.java:159)
   at org.apache.coyote.http11.InternalOutputBuffer.realWriteBytes(InternalOutputBuffer.java:215)
   at org.apache.coyote.http11.InternalOutputBuffer$OutputStreamOutputBuffer.doWrite(InternalOutputBuffer.java:240)
   at org.apache.coyote.http11.filters.IdentityOutputFilter.doWrite(IdentityOutputFilter.java:84)
   at org.apache.coyote.http11.AbstractOutputBuffer.doWrite(AbstractOutputBuffer.java:192)
   at org.apache.coyote.Response.doWrite(Response.java:504)
   at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:383)
   ... 73 more
spookybathtub
Postby Perforator » Wed Mar 05, 2014 10:34 am
Same errors here,
New install on a Tomcat6 + IBM Java 1.6.0 + SUSE SLES11 SP3
Perforator
Postby FUNTOWNE » Sun Aug 10, 2014 5:30 pm
Resurrecting this old thread to post the fix that worked for me:
try changing your downsample command from the ffmpeg string to lame:
lame -S -h --resample 44.1 -b %b --tt %t --ta %a --tl %l %s -
The above is my downsample command and it fixed my streaming over cellular.
FUNTOWNE
