Is there an app for the Surface?
Postby hnaparst » Sat Oct 27, 2012 2:45 pm
I tried to find the app in the Windows 8 app store, and I couldn't. I would be interested in using it on my Windows 8 desktop or on my Surface tablet.
Regards.
hnaparst
Re: Is there an app for the Surface?
Postby mr_nobody » Sat Oct 27, 2012 5:34 pm
Well you can use any of the windows apps on your win 8 desktop (or surface pro for that matter)...in terms of surface rt, someone would have to write an app for that...
mr_nobody
Postby manwithaplan » Sat Oct 27, 2012 10:50 pm
Couldn't you just use the browser on it and run the full blown Subsonic web UI?
manwithaplan
Postby mr_nobody » Sat Oct 27, 2012 11:06 pm
Doesn't the web app still depend on flash? Is there flash on rt?
mr_nobody
Postby GJ51 » Sun Oct 28, 2012 1:40 am
mr_nobody wrote:Doesn't the web app still depend on flash? Is there flash on rt?
Great question. I have the Win 8 RC running and I can run flash on that and all my Subsonic stuff plays back, but that's no guarantee that we'll be able to do the same on the final version or on RT. I'm up against the same issue with my Galaxy SIII phone as Jelly Bean locks out any attempt to load flash and I've lost the ability to play back videos when I recently flashed a Jelly Bean rom onto the phone and had to revert back to ICS.
EDIT: Solved the Android issue from instructions here:
http://liliputing.com/2012/07/how-to-in ... vices.html
Postby tsquillario » Tue Oct 30, 2012 6:49 pm
Jamstash Developer
Chrome App - https://chrome.google.com/webstore/detail/jccdpflnecheidefpofmlblgebobbloc
Beta Site - http://beta.jamstash.com
GitHub Project - https://github.com/tsquillario/Jamstash
tsquillario
Postby GJ51 » Tue Oct 30, 2012 7:30 pm
tsquillario wrote:We don't need no stinkin flash!
http://forum.subsonic.org/forum/viewtopic.php?f=12&t=10452
OK - how do you suggest playin back video through Subsonic on an Android device. Please share the set up.
Postby a811485 » Sat Nov 24, 2012 6:08 am
How does linking a plugin for chrome help playing back subsonic on windows surface RT?
a811485
Postby GJ51 » Sat Nov 24, 2012 5:38 pm
a811485 wrote:How does linking a plugin for chrome help playing back subsonic on windows surface RT?
It doesn't. I use Chrome on Win 8 but I was not aware that it wouldn't run on RT intil I saw your post and checked.
"Get a fast, free web browser
Google Chrome runs websites and applications with lightning speed.
Download Chrome
For Windows 8/7/Vista/XP. Not available for Windows RT."
I doubt that this is a commonly known fact.
Postby pestilent » Mon Nov 26, 2012 6:07 pm
Has anyone had any luck with subsonic on the Surface RT yet?
IE10 on the Surface comes with an embedded version of flash, but it is not recognized by Subsonic. Adobe has dedicated a page to compatibility issues with the version of Flash in IE10 on the Surface, but none of their suggestions helped (http://helpx.adobe.com/flash-player/kb/ ... 8-arm.html). I even tried manually white listing my SubSonic site in the IE Compatibility list.
I have also tried using MiniSub with no luck. The site opens with minimal issues (a few minor alignment issues), but nothing plays.
External player has also yielded nothing. "Music" launches, but does nothing.
pestilent
Postby daneren2005 » Mon Nov 26, 2012 6:38 pm
I would also be interested in a app for Windows 8. I pretty much avoid the web ui whenever possible since it is so awful to navigate in.
Postby GJ51 » Mon Nov 26, 2012 9:06 pm
pestilent wrote:Has anyone had any luck with subsonic on the Surface RT yet?
Typical MS. Subsonic runs fine in the browser on my Win 8 box in the rraditional IE 10 desktop browser, but if I try to connect from the Metro tile browser it says "This page cannot be displayed"
Go figure.
Leave it to MS to screw up everything that used to work just fine and then blame it on their users for not staying up to date.
Win 8 makes Vista look attractive.
Postby pestilent » Mon Nov 26, 2012 10:45 pm
To amend my last post, I finally got the subsonic site working on the Surface. I must have modified the wrong section of the white-list last time. Here's the instructions for changing the list (http://forum.xda-developers.com/showthr ... ?t=1961793). After adding my server I am now able to play music and video to play via flash on my surface.
pestilent
