Hi.
Is there an option to set the Recently added at startup screen and not the Random?
Greez
GJ51 wrote:I primarily use Madsonic for day to day use although I try to keep all the most recent variants up to date. All of the 4.7 variants I use correctly display new content after the nightly scan has run.
With either the Madsonic or the Music Cabinet you can easily select several start default views without editing jsp files as would be required in the standard Subsonic release.
If for some reason i decided to revert to an earlier Subsonic because of something I didn't like in 4.7, I'd actually go back to 4.5 instead of 4.6. 4.5 had fewer problems than 4.6 and was great for music only playback. 4.7 is much faster than previous versions, but does have its own set of issues.
I'm actually considering redoing a 4.5 site to test some of the problems we see with the Android app in 4.7 using Jelly Bean.
Unless you have a specific feature you like in 4.6, I think you'd like 4.5 or 4.7 much better. 4.6 had real problems with estimating track lengths.
With the 4.7 variants you can sometimes run into missing folders, but so far it has always been easy to fix by disabling all the media folders, cleaning the db, then reenabling and rescanning.
