Possible to add # to top of artist list in left-hand pane?
Postby jensonc » Tue Oct 30, 2012 11:01 pm
Is there an editable config file somewhere that defines how the left-hand artist list pane is structured? I miss the old versions where the # section was at the top. I know that I used to be able to edit the frame ratios and stuff within the main browser window, and I'd think that this setting could be found in that file as well, but for the life of me I cannot find it!! I've tried searching forums because I'm sure someone else has asked this before but couldn't find much.
Hopefully a simple enough request. Unless that particular config file is encased in some type of Java class file then I'm leaving it alone :)
Subsonic is AMAZING!!!
jensonc
Re: Possible to add # to top of artist list in left-hand pan
Postby BKKKPewsey » Wed Oct 31, 2012 12:42 am
Settings/General - Index
Postby jensonc » Wed Oct 31, 2012 12:50 am
BKKKPewsey wrote:Settings/General - Index
bahaha oh wow thank you so much, I totally forgot about the plain obvious answer and defaulted to it being hard-coded into the config files. Thanks so much boss!!! :)
jensonc
