Sharing playlists to guests
Postby iceolate » Fri Nov 30, 2012 3:43 pm
Sometimes I share albums to friends to listen to, rather than bothering to set them up with an account. This way they can listen to something as a guest. I noticed that still, for example, if I share an album, it will stop playing after a song is done. Does anyone know why this is? I would like it and should be set to play the thing like you were listening to an album.
As an example, I shared a Testament album I have. After each song, it stops, then I have to go to the share page and manually start the next song. Can this be fixed? I'm not sure if this was brought up in the past. Thanks
You can use this as an example, if you want: http://96.236.128.173/share/vNfwt
iceolate
