List all songs? Shuffle?
Postby WACOMalt » Sun Dec 30, 2012 6:17 pm
Hi there, I am not new to subsonic, been using it for over a year now, but I just today decided to shuffle my whole music library. I must be completely stupid but I cannot find a way to list all of my songs, add them to a playlist, and shuffle.
Or even just a simple shuffle all button. I think the old version of the android app had a shuffle option, but I just checked on the new app, and don't see it. How can I add all songs to a playlist, or shuffle all?
May I also take this moment to say that I was seriously annoyed that after buying ("donating") for the desktop server, and having been using subsonic on android for no added charge, to find that I now had to pay a 2nd time to not have my screen cluttered with ads... very lame. In any case, subsonic is still the best option. Please help me find shuffle :(
EDIT: to be clear I am trying to find "shuffle all" on the web interface, and ALSO on the new android app.
WACOMalt
Re: List all songs? Shuffle?
Postby mr_nobody » Sun Dec 30, 2012 7:38 pm
Doesn't exist. On the More tab, you can generate a random playlist of x songs but that's it.
[edit] : Don't use the official android app anymore (dsub is way better) but on the Home tab, there's a shuffle button that does what you want.
mr_nobody
Postby swedepete » Thu Jan 03, 2013 5:31 pm
What´s the limit of song subsonic can handle? all i can find is 100 000+ not the MAX the program can handle.
Happy if anyone could answer this question.
Thinking about using and sponsoring subsonic if it can handle 500000+ at least.
regards swedepete
swedepete
Postby flvinny521 » Mon Mar 11, 2013 1:59 pm
This is something that was frustrating me as well, but I think I have a work-around. I currently use MusicCabinet, which allows you to create a random playlist based on tags. Simply highlight every tag in your library and ask it to create a playlist, and you've basically shuffled all of your tracks. It's not as simple a solution as I'd like, but it seems to work.
Also, try uninstalling the Android app and using this one instead: http://forum.subsonic.org/forum/viewtopic.php?f=8&t=11303
Again, I don't use the official app, but I can navigate to the parent folder and shuffle every track using this app. I'm about to try dSub as well, so I'm not sure if that supports the same feature.
flvinny521
