streaming video default playing speed to 200?
Postby Beowolf » Wed Jan 09, 2013 4:35 pm
Hello
I was wondering if anyone knows where I can set the default play to 200 from 1000 for streaming
let me know if can be done and where
thanks
1,959 artists
1,970 albums
13,978 songs
941.65 GB (~ 14,628 hours)
Beowolf
Re: streaming video
Postby audioscavenger » Wed Jan 09, 2013 5:42 pm
??? what do you mean ?
audioscavenger
Re: streaming video
Postby Beowolf » Wed Jan 09, 2013 6:59 pm
when you stream video below it has 2 things
Open in new winder
a pull down selection of 200-5000kbps
i wish to make 200 default not 1000
1,959 artists
1,970 albums
13,978 songs
Beowolf
Re: streaming video
Postby Beowolf » Thu Jan 10, 2013 4:47 am
bump
1,959 artists
1,970 albums
13,978 songs
Beowolf
Re: streaming video default playing speed to 200?
Postby signalwarrant » Sat Jan 12, 2013 9:27 am
I would also love to know how to do this. I have about 800 movies and TV shows available to stream and about 400 users. Continual buffering is the problem I'm trying to solve.
signalwarrant
Postby GJ51 » Sat Jan 12, 2013 3:35 pm
signalwarrant wrote:I would also love to know how to do this. I have about 800 movies and TV shows available to stream and about 400 users. Continual buffering is the problem I'm trying to solve.
With that many users you have two problems to deal with. First CPU load as transcoding takes quite a bit of CPU power, and second is going to be upload bandwidth from the server. Even set as low as 200kbps if you have 10 users watching video you'll need 2000kbps going out just to service the video feeds, not including any other network traffic. Do the math if you're at 1000kbps times avg. # of users to determine minimum bandwidth needed, then realistically figure you'll probably need at least 50% more to have some overhead for other traffic.
CPU - each stream if it needs to be transcoded will max out even a very powerful server rather quickly. Transcoding is different than bandwidth strain as I've found that it seems the load increases proprotionally to the difference between the original bandwidth of the recorded video and the final output. This means thst if your taking 1080i recordings from TV and knocking it down to 200kbps it wiil take more CPU load than if it's only knocking it down to 1000kbps. That may be just my imagination as I haven't done any hard testing, but that's the way it feels to me in everyday use.
The best solution for video is to preformat to mp4 and bypass transcoding to alleviate CPU load, but then all the video goes out at much higher bandwidth.
With 400 users you probably need dual quad core CPU's at a min and 100/100 connection speed. I'm just guesstimating, but that's probably not too far off.
As an alternative you could use the Madsonic mod and limit access to video - not a cure, but it might help.
Postby Beowolf » Mon Jan 14, 2013 4:45 am
anyone make me a fix i broke arm and bruised ribs would love a fix
1,959 artists
1,970 albums
13,978 songs
Beowolf
Postby GJ51 » Mon Jan 14, 2013 6:00 am
Use good arm to ingest large quantities of alcohol.
Postby MadEvil » Thu Jan 17, 2013 5:05 pm
hi,
Default Video Bitrate comes with Madsonic Build 3320 ...
http://forum.madsonic.org/viewtopic.php?f=16&t=14
best regards
Madsonic Developer
MadEvil
