Subsonic + Pound
Subsonic + Pound
Postby SyberWraith » Tue Apr 09, 2013 12:26 am
I've been using subsonic for a while, and i really like it. My issue stems from my trying to use Pound reverse proxy on a Debian 6.0 box and subsonic running on a windows server 2008. Inside the network i can access it just fine going to https://subsonicip:4443/subsonic. I can also access this from outside my network because i forwarded port 4443 to the subsonic server.
However, i want to just https, and pound (so i can close off 1 more FW rule). the rule i have in pound is this:
ListenHTTPS
Address 192.168.20.17
Port 443
Cert "/etc/ssl/local.server.pem"
Service
URL "/Subsonic"
BackEnd
Address 192.168.20.12
Port 4443
End
End
End
I have pound working with no problems with OTRS on a different server (rule in pound is very similar). When i try https://poundserverip/subsonic, subsonic (or pound, not sure which) gives the error "The service is not available. Please try again later." This only happens when i try to use the Pound server. Obviously port 4443 is open since i can access subsonic when going directly to it's IP, and just as a precaution i specifically added port 80 and 443 to the firewall. Still the same error.
Let me know if i need to post any other info. Thanks for any assist.
SyberWraith
Re: Subsonic + Pound
Postby SyberWraith » Mon Apr 15, 2013 3:56 pm
Found what was wrong with my config, the section with /Subsonic should have been /subsonic. Wasn't seeing that and was having a brain fart about linux being case sensitive on everything. Once it was switched it works.
SyberWraith
Postby dragon2611 » Wed Apr 17, 2013 7:55 pm
How well does this work?
Do players/mobile clients seem to function Ok with it?
Currently I have HTTPS working in subsonic with a Self-signed certificate (Well actually It's signed by My own CA which my machines trust but obviously others won't) but I can see the appeal of this.
dragon2611
