Podcasts on 4.8
Podcasts on 4.8
Postby jsonnabend » Thu Jul 25, 2013 9:05 pm
I just upgraded to 4.8. The podcast feature does not work for me. I see all my podcasts in the podcast list, but they don't play. Any ideas?
TIA
- Jeff
jsonnabend
Re: Podcasts on 4.8
Postby jsonnabend » Fri Jul 26, 2013 8:25 pm
Well, just in case anyone else runs into this problem, here's how I solved it.
The issue turned out not to be a podcast issue per se, but instead had to do with playing mp3's. I followed the advice in this thread to "transcode from mp3 to mp3" and now everything works.
- Jeff
jsonnabend
Re: Podcasts on 4.8
Postby daneren2005 » Fri Jul 26, 2013 9:08 pm
That is weird in 4.7 he added a downscaling command so you shouldn't need to do that anymore. Oh well if it worked it worked. I have been having trouble with some podcasts playing so I wonder if that will fix it for me too.
Re: Podcasts on 4.8
Postby daneren2005 » Sat Jul 27, 2013 3:14 pm
And it worked, thanks for the tip
