Error Report
Error Report
Postby morpheus384 » Mon Nov 04, 2013 5:55 pm
org.springframework.dao.TransientDataAccessResourceException
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]
Java version Oracle Corporation 1.7.0_45
Server jetty-6.1.x
Memory Used 75 of 101 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.MediaFileDao.getChildrenOf(MediaFileDao.java:79)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:196)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:146)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:61)
at net.sourceforge.subsonic.controller.LeftController.getMusicFolderContent(LeftController.java:220)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:142)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]
... 65 more
morpheus384
Re: Bug Report
Postby morpheus384 » Mon Nov 04, 2013 5:57 pm
The above error report was generated last week. I'm unable to access my music in either the left panel or the main body of the gui online at present. Is there a quick fix for this?
morpheus384
Re: Error Report
Postby alphawave7 » Tue Nov 05, 2013 4:28 am
viewtopic.php?f=5&t=12276
Common error particularly when Java updates while Subsonic service was running. DB is corrupt.
Re: Error Report
Postby morpheus384 » Mon Nov 11, 2013 4:23 am
So can you recommend an easy fix for this error? I tried disabling Subsonic-->reinstalling Java-->Installing Subsonic 4.9 beta 1and Recscanning Database. That didnt work. Any guide to somving this error that someone can direct me to? Thanks in advance for any help you can offer.
morpheus384
Re: Error Report
Postby alphawave7 » Tue Nov 12, 2013 4:02 am
morpheus384 wrote:So can you recommend an easy fix for this error? I tried disabling Subsonic-->reinstalling Java-->Installing Subsonic 4.9 beta 1and Recscanning Database. That didnt work. Any guide to somving this error that someone can direct me to? Thanks in advance for any help you can offer.
o Stop Subsonic.
o Remove c:\subsonic\db
o Start Subsonic.
You will of course lose your settings.
Re: Error Report
Postby morpheus384 » Thu Nov 14, 2013 7:36 pm
Many thanks, that did the trick. Reescanning databases now! :D
morpheus384
