Android App Crashes whenever you try to search
Postby ninjapuffin » Sun Dec 15, 2013 3:50 am
I go into the android app and go to the library tab then I hit the search at the top of the screen and type a search. The app then crashes with "Unfortunately Subsonic has stopped," and allows you to report the error. I have done this several times.
hopefully a fix is on its way because i use the search function quite frequently.
I am using Subsonic v4.1
Thanks.
ninjapuffin
