Failed to import playlist. No songs in the playlist were...
Postby DjSmooth » Tue Mar 25, 2014 8:17 am
Why? This is just driving me crazy, all my folders has Playlists, and even when I try to Upload them from the folder I get this message: "Failed to import playlist. No songs in the playlist were found" I have at least 600 Playlist and SS recognizes all my music but not one Playlist. Even tried the "Playlist Folder" thing, that was unsuccessful as well. I would hate to think that I will have to manually create these playlist via SS. Does anyone have any ideas that could help me out! Thanks
DjSmooth
Re: Failed to import playlist. No songs in the playlist were
Postby jewahe » Sat May 17, 2014 5:15 am
I'm just getting started, and hit the wall with this issue, as well. The problem turned out to be that the paths within the file were relative instead of absolute.
For example, if I have my music folders set up as follows
C:\
    Media
      Music
The playlists are being stored in the Media folder.
A relative path is \Music\Artist\Album\Track.mp3 (it's "relative" to the location where the playlist is stored).
The absolute path is C:\Media\Media\Music\Artist\Album\Track.mp3
Once I converted all the paths to absolute paths, I no longer had an issue with the import.
You can edit the playlist. I used NoteTab Light, a more advanced text editor than NotePad.
jewahe
