Subsonic on Wildfly 8 and JDK 1.7.0
Postby jocke4u » Mon Mar 31, 2014 4:01 pm
I try to deploy Subsonic 4.9 on Wildfly 8.0.0 running JDK 1.7.0 but get
Internal Server Error
    "outcome" => "failed",
    "failure-description" => {"JBAS014671: Failed services" => {"jboss.deployment.unit.\"subsonic.war\".PARSE" => "org.jboss.msc.service.StartException in service jboss.deployment.unit.\"subsonic.war\".PARSE: JBAS018733: Failed to process phase PARSE of deployment \"subsonic.war\"
    Caused by: org.jboss.as.server.deployment.DeploymentUnitProcessingException: JBAS017302: Failed to parse XML descriptor \"/C:/server/wildfly-8.0.0.Final/bin/content/subsonic.war/WEB-INF/lib/string-1.1.0.jar/META-INF/taglib.tld\" at [713,18]"}},
    "rolled-back" => true
jocke4u
Re: Subsonic on Wildfly 8 and JDK 1.7.0
Postby jocke4u » Mon Mar 31, 2014 5:11 pm
Found something here: https://community.jboss.org/thread/2036 ... =0&_sscc=t
But deployment fails anyway but with an other error:
    "failure-description" => {"JBAS014671: Failed services" => {"jboss.deployment.unit.\"subsonic.war\".WeldStartService" => "org.jboss.msc.service.StartException in service jboss.deployment.unit.\"subsonic.war\".WeldStartService: Failed to start service
    Caused by: org.jboss.weld.exceptions.DeploymentException: WELD-001408: Unsatisfied dependencies for type LogCategories with qualifiers @Default
  at injection point [BackedAnnotatedField] @Inject protected org.fourthline.cling.support.shared.log.impl.LogViewImpl.logCategories
  at org.fourthline.cling.support.shared.log.impl.LogViewImpl.logCategories(LogViewImpl.java:0)
jocke4u
Postby supra92 » Mon Aug 04, 2014 2:15 pm
Hey jocke4u,
I just tried installing Subsonic on Centos 7 + Wildfly 8, and ran into the same exact two error messages, in sequence, as you did a few months ago.
First error (taglib.tld) was resolvable by exploding the subsonic.war file, then exploding the string_1.1.0.jar file, changing the "EMPTY" to "empty" (lowercase), and then re-jarring and re-warring.
But, I've now run into that same second error as you did, with the WELD-001408 Unsatisfied dependencies for type LogCategories..." error.
Were you ever able to reach a resolution on this one?
Rgds,
Supra92
supra92
Postby jocke4u » Tue Aug 05, 2014 12:26 pm
jocke4u
Postby supra92 » Tue Aug 05, 2014 4:12 pm
Ah fantastic, thankyousir -- going to try that today, and will let you know how it goes. I'll reply with the results in your new referenced thread, so it's a one-stop-shop for others dealing with similar situation.
Cheers,
Supra92
supra92
