(5.0) Video broken under reverse proxy due to wrong domain.
Postby chris.henderson » Sat Sep 27, 2014 12:41 am
This issue did not exist for me in this form in 4.9.
Under a reverse proxy the client will attempt to access the proxied domain rather than the proxy itself when retrieving crossdomain.xml and the video stream itself. This results in a "Video not found or access denied" error.
Example Chrome console output:
(http://i168.photobucket.com/albums/u171 ... bsonic.png)
You can see that the client is attempting to use the name of my upstream block as the domain to reference (without using the upstream block the above simply changes from http://subsonic/subsonic/foo%20bar to http://localhost:4040/subsonic/foo%20bar).
Subsonic is reverse proxied by Nginx with the following relevant configuration
upstream subsonic {
        server localhost:4040;
location /subsonic {
        proxy_pass              http://subsonic;
        proxy_set_header        X-Real-IP  $remote_addr;
        proxy_set_header        X-Forwarded-Host $host;
        proxy_set_header        X-Forwarded-For $proxy_add_x_forwarded_for;
Subsonic's default config:
SUBSONIC_HOST=127.0.0.1
SUBSONIC_PORT=4040
SUBSONIC_CONTEXT_PATH=/subsonic
SUBSONIC_ARGS="--max-memory=5120 --host=${SUBSONIC_HOST} --port=${SUBSONIC_PORT} --context-path=${SUBSONIC_CONTEXT_PATH}"
I've managed a workaround by adding...
129.219.26.2 subsonic
...to each client's hosts file so that it can actually resolve the name, but this is unsatisfactory as even a medium term response.
Does anyone know of an Nginx directive for making the player more aware of its position in the proxy? Or point me to where in the code I can set this straight?
Thank you, very much.
chris.henderson
Re: (5.0) Video broken under reverse proxy due to wrong doma
Postby Rezero » Sat Sep 27, 2014 2:27 am
Wanted to log in to confirm this. I use Apache's ProxyPass feature to route requests to mydomain/subsonic to 127.0.0.1:4040/subsonic. This works fine for music, but any attempts to play video result in the player looking at http://127.0.0.1/subsonic instead of http://mydomain/subsonic.
Rezero
Postby daily-freak » Mon Sep 29, 2014 11:56 am
I can also confirm this problem. This is happening for me using apache2 (up to date), gentoo linux und standalone-subsonic with reverse-proxy. A fix would be nice. For example when serving the Video-Url extract the domain out of the request-header.
Greetings
Edit: I did a small research on this..
This is the source of the video-controller in 4.9
http://sourceforge.net/p/subsonic/code/ ... oller.java
And this in 5.0
As you can see the handling of the video urls has changed I think according to the new player. in 4.9 the original request and response have been forwarded, now they are interpreted in the controller. There is the error. Currently I have no solution. Maybe if I have time I will check if I find a solution. But a solution by sindre would be nicer because her really knows what he is doing there and why he is doing it
daily-freak
Postby chris.henderson » Mon Sep 29, 2014 2:32 pm
daily-freak wrote:...
And this in 5.0
I have my hunches. In there we have lines 71-74:
        String remoteStreamUrl = StringUtil.rewriteRemoteUrl(streamUrl, urlRedirectionEnabled, urlRedirectFrom,
                urlRedirectContextPath, localIp, localPort);
        String remoteCoverArtUrl = StringUtil.rewriteRemoteUrl(coverArtUrl, urlRedirectionEnabled, urlRedirectFrom,
Which uses net.sourceforge.subsonic.util.StringUtil.rewriteRemoteUrl:
    public static String rewriteRemoteUrl(String localUrl, boolean urlRedirectionEnabled, String urlRedirectFrom,
            String urlRedirectContextPath, String localIp, int localPort) throws MalformedURLException {
        URLBuilder urlBuilder = new URLBuilder(localUrl);
        if (urlRedirectionEnabled) {
            String subsonicHost = urlRedirectFrom + ".subsonic.org";
            urlBuilder.setProtocol(URLBuilder.HTTP);
            urlBuilder.setHost(subsonicHost);
            urlBuilder.setPort(80);
            if (StringUtils.isNotBlank(urlRedirectContextPath)) {
                urlBuilder.setFile(urlBuilder.getFile().replaceFirst("^/" + urlRedirectContextPath, ""));
        } else {
            urlBuilder.setHost(localIp);
            urlBuilder.setPort(localPort);
        return urlBuilder.getURLAsString();
It kind of looks like urlRedirectionEnabled is a semaphore for having a subsonic.org subdomain. If not a subsonic.org subdomain then just concatenate the protocol, local ip, and local port in a URLbuilder. Those two were set back in the VideoController at lines 69-70:
        String localIp = settingsService.getLocalIpAddress();
        int localPort = settingsService.getPort();
Which are just getters from the net.sourceforge.subsonic.service.SettingsService (http://sourceforge.net/p/subsonic/code/ ... java#l1242).
I may have read urlRedirectionEnabled wrong, but overall it looks like the VideoPlayerController has taken on URL writing responsibilities without covering the case of a reverse proxy. I would love to work on a fix (no sarcasm!) but I just don't have the time nor wherewithal. However, hopefully this gets contributors on the right path.
chris.henderson
Postby phillipah » Wed Oct 01, 2014 8:18 pm
I am having the same problem... Anyone know when we can see a fix?
phillipah
Postby shikasta » Sun Oct 12, 2014 1:40 pm
I too have this issue when using an Apache proxy. I believe the actual problem is that the new rewrite settings assume only two contingencies: passthrough on port 4040 to subsonic (by setting --host in /etc/defaults/subsonic), or use of a subdomain YOU.subsonic.org.
The parameter UrlRedirectFrom in subsonic.properties sets this subdomain, and is read elsewhere using settingsService.getUrlRedirectFrom() and appending ".subsonic.org". Unfortuantely, simply removing ".subsonic.org" from everywhere this appears and brute forcing it to my actual host domain doesn't quite work, so I suspect I have missed a step somewhere.
It would be far more to the point to replace the "easy to remember address" setting on the Settings > Network page, with something that accepts a fully qualifying domain name, and maybe with auto-complete to .subsonic.org for convenience. Then this would work correctly with the current two contingencies and any other host name.
shikasta
Postby Chronic » Mon Oct 13, 2014 6:06 pm
This is a dealbreaker for me. Rolled back to 4.9 until this gets fixed.
Chronic
Postby phillipah » Fri Oct 31, 2014 4:33 am
bump... please can someone fix this...
phillipah
Postby shikasta » Fri Oct 31, 2014 11:45 am
Not a fix, but workaround that works:
http://techblog.jeppson.org/2014/09/fix ... 0-upgrade/
The key is to insert
ProxyPreserveHost on
into your apache VirtualHost config, before the proxypass
shikasta
Postby phillipah » Fri Oct 31, 2014 4:55 pm
shikasta wrote:Not a fix, but workaround that works:
That worked for me! Thanks!
Another thing i wanted to add is that in my configuration i have all http requested getting redirected to https and it still worked just fine. I thought i would have to allow the stream to be http but it was not necessary.
phillipah
Postby daily-freak » Fri Nov 14, 2014 10:21 am
Didn't work for me. It should work if your Server is reachable over http, but if you are using https the URL is being resolved to "http://<yourUrl>" which leads to a 404.
Greetings
daily-freak
Postby chris.henderson » Wed Nov 19, 2014 1:44 pm
Note that the analog to this in Nginx is the following:
proxy_set_header Host $host;
And yes, it appears to be working for now. Thank you.
chris.henderson
Postby Rezero » Fri Nov 28, 2014 2:01 am
daily-freak wrote:Didn't work for me. It should work if your Server is reachable over http, but if you are using https the URL is being resolved to "http://<yourUrl>" which leads to a 404.
Greetings
In this case, you should enable SSL through Subsonic and set up forwarding to Subsonic's HTTPS port. The extra overhead is unwelcome, but minimal, and it will correctly resolve to https://<mydomain>
Rezero
