Upgrading to Subsonic 5.0
Postby jdblaich » Wed Oct 01, 2014 5:33 pm
After upgrading from the beta of 5.0 to the official release of 5.0 it looks like the flash player is no longer loading. When I attempt to play a song it tries to send me a playlist (.m3u) file.
I tested it with dsub on andoid and that works properly.
I tested flash in the browser on various sites. It is working properly on those sites.
Any fix? No, I don't want to remove and reinstall.
jdblaich
Re: Upgrading to Subsonic 5.0
Postby daneren2005 » Wed Oct 01, 2014 5:36 pm
Delete all existing players, log out, then back in. That is an issue that has nothing to do with the upgrade and I have never been able to figure out what the heck is causing it.
Postby jdblaich » Wed Oct 01, 2014 9:12 pm
How do I delete all players?
When it ran under the beta it worked. After the official release it didn't.
jdblaich
Postby daneren2005 » Wed Oct 01, 2014 9:22 pm
It is under settings.
Postby jdblaich » Wed Oct 01, 2014 10:22 pm
It had the wrong player selected. Somehow between the update from beta to official it changed my player to external player. I only had to change it to web player and save the settings.
That was frustrating. That is, because, it was difficult to know who caused the issue thus where to go to get the correct fix.
jdblaich
