Subsonic 5 on OpenWRT
Postby dana44 » Sat Nov 22, 2014 6:02 am
On my Windows 8.1 PC I see the subsonic process using 63MB private and 315MB virtual as measured by Process Explorer. With a router like the wrt1900ac with just 256MiB would I be able to run subsonic on it if I switched to OpenWRT/McWRT?
I assume the 1.2GHz dual core processor will be able to keep up with the transcoding just fine.
dana44
Re: Subsonic 5 on OpenWRT
Postby Reith » Sun Nov 30, 2014 10:18 pm
You realize the transcoding is done on your computer, not the router, right..?
Reith
Postby Byronnnn » Tue Dec 16, 2014 2:55 pm
Reith wrote:You realize the transcoding is done on your computer, not the router, right..?
He is talking about actually installing Subsonic on the router, which is possible. In this case it would transcode on the router since it would be completely independent from a computer.
And to address his question, I have never been able to get it working properly enough to test transcoding. However, if you do get it working, I would be curious to know how it works.
Byronnnn
Postby Exrace » Mon Jan 12, 2015 5:15 am
Think performance would suffer greatly but would be interesting to see how well the code does.
Exrace
