Upgrading from 5.1 beta 2 to 5.1 stable
Postby crashoverride025 » Thu Jan 22, 2015 5:09 pm
I just tried to upgrade from 5.1 beta 2 to the 5.1 stable release. When doing so I got the error below. I'm upgrading via tomcat with a Java 8 JDK.
First error:
org.apache.jasper.JasperException: Unable to compile class for JSP:
An error occurred at line: 1 in the generated java file
The type java.util.Map$Entry cannot be resolved. It is indirectly referenced from required .class files
Stacktrace:
   org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:102)
   org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:331)
   org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:469)
   org.apache.jasper.compiler.Compiler.compile(Compiler.java:378)
crashoverride025
Re: Upgrading from 5.1 beta 2 to 5.1 stable
Postby crashoverride025 » Fri Jan 23, 2015 6:08 pm
This issue was caused due to an upgrade from Java 7 to 8, and using Tomcat 7.0.33. Tomcat 7.0.33 does not have great Java8 support. So an upgrade to Tomcat 7.0.57 was required.
crashoverride025
Postby Exrace » Sat Jan 24, 2015 1:37 pm
Thanks for the heads up.
Exrace
