[Android App] SSL Bug (Android 5)
Postby daben » Fri Jan 23, 2015 9:10 am
Since my Upgrade to Android 5 the App is not able to connect to my Subsonic server via TLS on Port 8443 anymore. It worked fine with Android 4.x and is still working on other devices with Android 4.x.
daben
Re: [Android App] SSL Bug (Android 5)
Postby Exrace » Sat Jan 24, 2015 1:38 pm
Which app are you referring to?
Exrace
Postby Salzi » Mon Feb 02, 2015 2:26 pm
Hi
Unfortunately I have the same issue.
On all android devices with android version < 5 the subsonic app for android works great. On all my android devices with android version >= 5 (lollipop) I can't connect to the server: Connection failure. A network error occurred.
Subsonic (5.1 (build 4340)) itself runs on a debian server with apache and a self signed certificate.
Any suggestions?
Update: Tested with DSub (fork of the subsonic app) and that one works...
Salzi
