Subsonic errors out on PC and Android
Postby erichduff » Sat Aug 15, 2015 2:20 am
I get this error on both PC and android. Any ideas what's going on? (The Subsonic browser page suggested I copy and paste the info below to the forums...)
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version Oracle Corporation 1.8.0_31
Operating system Windows 8 6.2
Server jetty-6.1.x
Memory Used 62 of 145 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:97)
at net.sourceforge.subsonic.dao.MediaFileDao.getChildrenOf(MediaFileDao.java:85)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:197)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:181)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:63)
at net.sourceforge.subsonic.service.MusicIndexService.getMusicFolderContent(MusicIndexService.java:73)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:131)
Caused by: java.sql.SQLException: out of memory
... 64 more
erichduff
