External SD Card ?
External SD Card ?
Postby jkearns97062 » Sat Dec 19, 2015 10:25 pm
Sorry, I know this has been discussed, but I couldn't figure out the net net.
Can DSub be moved and/or have music files on the external SD card on Lollipop?
Jerry
jkearns97062
Re: External SD Card ?
Postby daneren2005 » Sat Dec 19, 2015 11:07 pm
Yes you should be able to if you keep everything the same except for changing the root point (ie something like internal -> ext_sdcard. I really just need to change it on KitKat+ to just give a few options on what path to use since you can't really free form it anymore due to system limitations.
