Build error r4608
Build error r4608
Postby phillipmcmahon » Thu Jan 07, 2016 9:05 am
Hopefully this is a supported request...
I checked out r4608 this morning and attempted to compile but am faced with an error. All previous check outs have compiled fine which suggest my build env is correct and maybe something with this revision isn't. Let me know if I should attache a specific surefire report, for now the console error output is shown below
Running net.sourceforge.subsonic.io.RangeOutputStreamTestCase
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.004 sec <<< FAILURE!
testWrap(net.sourceforge.subsonic.io.RangeOutputStreamTestCase) Time elapsed: 0.003 sec <<< ERROR!
java.io.IOException
at net.sourceforge.subsonic.io.RangeOutputStream.write(RangeOutputStream.java:100)
at net.sourceforge.subsonic.io.RangeOutputStreamTestCase.copy(RangeOutputStreamTestCase.java:94)
at net.sourceforge.subsonic.io.RangeOutputStreamTestCase.doTestWrap(RangeOutputStreamTestCase.java:72)
at net.sourceforge.subsonic.io.RangeOutputStreamTestCase.testWrap(RangeOutputStreamTestCase.java:37)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at junit.framework.TestCase.runTest(TestCase.java:164)
at junit.framework.TestCase.runBare(TestCase.java:130)
at junit.framework.TestResult$1.protect(TestResult.java:110)
at junit.framework.TestResult.runProtected(TestResult.java:128)
at junit.framework.TestResult.run(TestResult.java:113)
at junit.framework.TestCase.run(TestCase.java:120)
at junit.framework.TestSuite.runTest(TestSuite.java:228)
at junit.framework.TestSuite.run(TestSuite.java:223)
at org.junit.internal.runners.OldTestClassRunner.run(OldTestClassRunner.java:35)
at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:252)
at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:141)
at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:112)
at org.apache.maven.surefire.util.ReflectionUtils.invokeMethodWithArray(ReflectionUtils.java:189)
at org.apache.maven.surefire.booter.ProviderFactory$ProviderProxy.invoke(ProviderFactory.java:165)
at org.apache.maven.surefire.booter.ProviderFactory.invokeProvider(ProviderFactory.java:85)
at org.apache.maven.surefire.booter.ForkedBooter.runSuitesInProcess(ForkedBooter.java:115)
at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:75)
Thanks in advance.
Phill
phillipmcmahon
Re: Build error r4608
Postby phillipmcmahon » Sat Jan 09, 2016 8:42 am
For now I disabled the test. Anyone with a better solution?
phillipmcmahon
